Installing Doors On Existing Tub. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 02-01-2017, 09:29 AM   #1
Rewards Points: 76
Installing doors on existing tub.
Good morning. I have a tub that im tired of having the shower curtains. Is it OK to install framed shower doors on top of tub. The Tub is not plastic i believe its porcelain.would i have to make holes on the tub for the track or the holes would only be in the walls?
Sent from my LGLS676 using Tapatalk
charles3526 is offline   Reply With Quote
Old 02-01-2017, 06:51 PM   #2
Rewards Points: 17,884
Re: Installing doors on existing tub.
No pictures?
How do you plan on attaching it to the walls if there's no blocking behind them?
Any shower door track I've seen has no screws at the bottom of the track.
jlhaslip likes this.
Old 02-01-2017, 07:28 PM   #3
jlhaslip's Avatar
Rewards Points: 708
As Joe pointed out above, there usually are no holes to drill in the tub itself, but there are screws that go into the wall that need either support by way of blocking/backing or you must use some sort of anchor in the drywall which is not quite as secure but might be doable.
You might be wise to add additional holes in the verticals to allow for additional anchors for more support, too.
Another trick is to only caulk (silicone) the outside of the horizontals. That way, if any water gets behind the extrusions, it can drain back into the tub.
Hope this helps.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-01-2017, 10:30 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 748
So, if there's usually no holes in the bottom track, when are there holes?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-02-2017, 12:10 AM   #5
jlhaslip's Avatar
Rewards Points: 708
Jaz
Was this question directed to me? or the OP?
Old 02-02-2017, 11:10 AM   #6
Tileguy
JazMan's Avatar
Rewards Points: 748
Sorry no time to xplain in detail now.
Jaz
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 02:21 PM
Installing prehung doors - before or after resurfacing if walls? cstrasz Windows and Doors 1 03-10-2012 06:36 PM
Installing French Doors in Existing Exterior Wall Aarons Windows and Doors 11 08-08-2011 01:32 AM
Installing a Door in an existing pass-through gbarron1 Building & Construction 2 03-17-2005 03:47 PM
