Install Vanity On Tiled Wall, No Stud Behind - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-17-2018, 05:58 AM   #1
Rewards Points: 1,176
Install vanity on tiled wall, no stud behind
I'm almost finished remodeling my half bathroom, I just need to install the vanity (24" wood cabinet)
How can i install it knowing the wall is tiled, and on there is no stud where the vanity will be located?
Should I just use silicone on the back of the sink for example?
french_guy is offline   Reply With Quote
Old 05-17-2018, 06:21 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,594
Re: Install vanity on tiled wall, no stud behind
That is a free standing vanity, and unless the manufacturer stipulates otherwise, it requires no fastening to the wall. You can run a bead of silicone on the back of the sink part, as well as around the rim where it rests on the wood. Then finish off the trim by using silicone around the point where it is attached to the wall.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 05-17-2018, 06:56 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
Seems strange there us no stud in 24". If you can't find it, use toggle bolts.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Double Stud Wall Retrofit With XPS Sandwich kaalapurushha Insulation 3 08-02-2014 09:28 AM
New wall-mount vanity, but huge hump in wall M3 Pete Remodeling 4 04-18-2012 11:33 PM
How can I install this vanity without removing the top? Haleon General DIY Discussions 13 09-25-2010 01:13 PM
Vanity install tate16t Remodeling 3 09-13-2008 07:48 AM
