How Would You Finish Around My Shower? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 11:35 AM   #1
How would you finish around my shower?
the space between the shower and where the walls cuts back to the doorway is 1 1/2 " the depth of the shower receding into the wall is 1/4". Any ideas of how you "pros" would finish it off?
Edit: i did not install the shower, it was the last owners who did.
How would you finish around my shower?-photo-1.jpg   How would you finish around my shower?-photo-2.jpg
hit_em is offline   Reply With Quote
Old 02-22-2012, 02:32 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,134
1. Remove the door casing.
2. Cut everything else (except the shower) that protrudes from the wall down to the studs.
3. Use some new material as an oversized door casing (to cover all the ugly).
Old 02-22-2012, 07:30 PM   #3
Pure Genius
Rewards Points: 150
Tape and mud. Or cut back your drywall and install new so that it covers the nailing flange.
Dierte is offline   Reply With Quote
Old 02-23-2012, 03:00 PM   #4
Rewards Points: 512
i'd chaulk it
princelake is offline   Reply With Quote
Old 02-23-2012, 03:01 PM   #5
Rewards Points: 512
thats pretty ugly, only thing that comes to mind is using pvc casing and case the shower unit
Old 02-23-2012, 06:24 PM   #6
Thanks for the replies and ideas. I was figuring i would have to drywall and mud it because it goes all the way around the shower. I just hate doing drywall.
Chaulk it Thats what my wife told me to do.
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
