How Thick Should A Dry Mix Shower Pan Be? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-11-2017, 05:10 PM   #1
Rewards Points: 150
How thick should a dry mix shower pan be?
Is there a min tickness. My shower is 4' X 6'5" I want the thickness around the shower drain to be an inch but around the perimeter it goes from 2" - 1-1/2" because the existing floor is not level (this is a curbless shower) I can add an additional 1/2" to 3/4" to the subfloor in the bathroom area outside the shower to allow an additional 1/2" - 3/4" of concrete shower pan if it's necessary.
I'm covering the shower pan / mortar bed and durock with kerdi membrane and thinset.
What say you old wise ones of the DIY Forum?
Kemper100 is offline   Reply With Quote
Old 11-13-2017, 10:59 AM   #2
Rewards Points: 150
Re: How thick should a dry mix shower pan be?
I'll answer myself - I would add 3/4" just because MOAR is better...
Old 11-13-2017, 04:16 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,674
Insure that you have adequate slope when building your preslope. That will depend on the size of the shower base. 1/4" per foot at least. Then your liner and your slope, so you may have up to a few inches by the time it is over, again depending on size.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Kemper100 (11-14-2017)
Old 11-14-2017, 06:39 PM   #4
Rewards Points: 150
I made the thickness around the drain 1-1/4" and around the perimeter it goes from 2" - 2-1/2" thick. No liner just Kerdi membrane covering.
Button broke on Shower Head that redirects water to Handheld Massager ace2013 Plumbing 2 01-19-2014 09:18 AM
Framing the spline for a shower door miamicuse Kitchen & Bath Remodeling 6 04-20-2012 05:52 AM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
