How To Remove A TALL Kitchen Pantry Cabinet - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 1 Post By Mystriss
  • 1 Post By Nealtw
Old 12-01-2019, 03:10 PM   #1
Rewards Points: 2
How to remove a TALL Kitchen Pantry Cabinet
I'm attempting to remove a 7ft tall one piece kitchen pantry cabinet. I have removed the screws from the back of the cabinet which is holding it securely to the wall studs. I have also removed all the screws I can find from the right side of the cabinet which has secured it to the cabinets and countertop in the kitchen. The left side of the tall cabinet is the finished side as there are no more cabinets on the left side.
I removed all the floor moldings around the bottom of the tall pantry cabinet and the baseboard immediately to the left of the cabinet I wish to remove. In addition to removing all the screws I've found and the additional trim work; I have cut along the outside countertop and the backsplash with a razor knife to loosen the presence of any glue, caulking and/or grout. We get absolutely NO wiggle room on this cabinet, let alone getting it to move forward or to the side.
Are there other areas that people normally secure a tall cabinet that I have missed? Where else might I look for screws holding this cabinet into place? Is it possible they have glued this to the back wall? Any ideas on why I cannot get this cabinet to move would be greatly appreciated.
If at all possible I'd prefer to salvage this cabinet as I wanted to simply swap places with the refrigerator and this cabinet. Worse case I will not be able to salvage this cabinet but simply remove it in pieces.
I've attached a photo of the pantry I'm trying to take out.
kds308 is offline   Reply With Quote
Old 12-01-2019, 03:14 PM   #2
retired framer
Rewards Points: 1,244
Re: How to remove a TALL Kitchen Pantry Cabinet
Have you looked behind the hinges for screws from one cupboard to the other.
firehawkmph likes this.
Do not use flat bottom gables with scissor trusses.
Old 12-02-2019, 08:17 AM   #3
Mystriss's Avatar
Rewards Points: 3,688
Might check the bottom, we screwed ours into our home-made toe-kick, which is then screwed into the walls and floor.
Nealtw likes this.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is online now   Reply With Quote
Old 12-02-2019, 08:55 AM   #4
ZZZZZ's Avatar
Rewards Points: 2,832
My old cabinets were secured like that, but there was a lot of wiggle room at the top.
To me,.no wiggle room at all implies the back of the cabinet is glued to the back wall.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 12-02-2019, 09:44 AM   #5
hkstroud's Avatar
Rewards Points: 6,072
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 12-02-2019, 04:31 PM   #6
Mystriss's Avatar
It'd be icky if it was glued >.<
Old 12-02-2019, 07:41 PM   #7
Rewards Points: 440
Never seen any cabinet glued to another either. Second the idea of checking behind the hinges for screwing from one cabinet to the other. Also, second @Mystriss es thoughts on screwing from the bottom of the cabinet into the floor or into site made kick base support.
Another thought I had was was to check in the back corner of the cabinets to see if there may be an angled screw starting from the pantry or from the upper cabinet, or lower cabinet, that would grab and hold the cabinet.
Did you check along the top of the cabinet? Along the side and the back?
Those contractors are sneaky and will hide screws where you never thought possible.
Make sure you run a blade along ALL edges of the cabinet. Back, sides, top, bottom. Even if it doesn't look like there may be something. Also, take a wide, thin blade, like you would use for spackle, and make sure that you can slide it between the pantry cabinet and the sides. Use a soft blow hammer to force it between the cabinet and whatever it is next to.
If it still not moveable after all this effort, then you have one last choice and that is whack the heck out of it and plan on getting a new one.
The only stupid question is the one you DON'T ask!
Forgive me if I Mansplain things, I don't know what you know and I like to be thorough.
And most of all, have fun. It pisses some people off and makes others laugh.
ktownskier is offline   Reply With Quote
Old 12-02-2019, 07:51 PM   #8
retired framer
Always like people who ask questions and never come back for the answers.
bstiber likes this.
Old 12-02-2019, 07:57 PM   #9
RockyMtBeerMan's Avatar
Location: High in the Rocky Mountains, away from the herd.
Rewards Points: 310
Might be some L brackets or board at the top securing it to the wall.
RockyMtBeerMan is online now   Reply With Quote
Old Yesterday, 02:51 PM   #10
Rewards Points: 4
Are there rails on the back of the cabinet or tracks for mounting to the wall? Many of the cabinets that I install these days use a rail system. Never heard of using glue as a good means of securing cabinets to the wall.
bstiber is offline   Reply With Quote
Old Yesterday, 03:20 PM   #11
Rewards Points: 440
Gosh darn it, I also hate it when it's a single poster. I tend to take a bit more time in posting my replies due to my mansplaining tendencies. (NO! @Mystriss , I am NOT OCD, same goes for you to @Nik333 )
Oh, wait, my apologies for jumping the gun, I did not mean to impugn your reputation on an unwarranted assumption. (See Santa, I am TRYING to be less naughty and more nice!!)
Old Today, 08:45 PM   #12
Mystriss's Avatar
@ktownskier Hey! I'm mildly OCD. ~outrage~ LOL
Tags
cabinet , pantry , remodel , removing , salvage
