How To Remove Scratches From Porcelain Shower Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-28-2015, 07:46 AM   #1
Avy
Rewards Points: 4
Unhappy
How to remove scratches from porcelain shower pan
Hi I had a brand new porcelain shower pan/ base installed. The plumber scratched the pan. How do I remove these scratches. Also I don't know if it is better to remove the scratches or get a new shower pan/ base.
Avy is offline   Reply With Quote
Old 10-28-2015, 08:23 AM   #2
Rewards Points: 107
Plumber scratched the pan? Shouldn't he be fixing or replacing?
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
JazMan (10-28-2015)
Old 10-28-2015, 08:45 AM   #3
Avy
Rewards Points: 4
I was told that the plumber made an effort to fix the scratches. The problem is although the surface looks shiny and feels smooth you can still see the scratches when you have a closer look. Also, the scratches is quite a lot, all over the shower base. The developer don't see the reason to replace the shower base. Also have similar problem with bath tub.
Old 10-28-2015, 10:01 AM   #4
Rewards Points: 107
What is the tub and shower made of? If it scratches this easily if will like be a long term issue. Is this a remodel or new construction?
Old 10-28-2015, 10:58 AM   #5
Knows Enough to be Danger
Rewards Points: 1,203
So when you showed the developer the scratched tub he told you to go fly a kite?
Any pictures of this stuff?
NickTheGreat is offline   Reply With Quote
The Following User Says Thank You to NickTheGreat For This Useful Post:
JazMan (10-28-2015)
How do I remove this shower faucet cartridge? Tco0085 Plumbing 5 07-14-2012 10:14 PM
Replace shower pan- need to remove tile? Tricede Kitchen & Bath Remodeling 1 07-05-2012 10:34 AM
How to remove shower valve? rabel Plumbing 6 02-24-2012 06:30 PM
Shower arm broke off in pipe. Any suggestions to remove? mav1c Plumbing 6 08-09-2010 07:01 AM
Remove gold finish from shower fixtures? howagood Plumbing 1 07-26-2008 10:47 PM
