How Much Room For Fridge In Enclosed Area? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-14-2018, 11:46 AM   #1
Rewards Points: 104
How much room for fridge in enclosed area?
For a kitchen remodel project, my plan is to have the side of the fridge sit against one wall while the other side abuts a cabinet with a counter top. I understand the concerns about depth and handles and allowing the door to open and for ventilation, etc. My question is more generic than that and it concerns not the depth, but the width.
How much space should I leave on either side of the fridge such that it will fit neatly into it's cubby without looking like it's too small for the space? Is there a standard for this? 1/8" on both sides of the fridge enough? Is there any reason why the fridge would need more room than this for ventilation?
petermole is offline   Reply With Quote
Old 08-14-2018, 05:17 PM   #2
Rewards Points: 6,873
Re: How much room for fridge in enclosed area?
Probably not for ventilation.
But, the side that sits against the wall is going to need more than that if you want the door on that side to fully open. If it does not then drawers and shelves are not going to slide out properly. The doors need to open more than 90 degrees for proper operation, best WAG is 110-120 degrees.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 08-14-2018, 05:24 PM   #3
retired framer
Rewards Points: 18,366
If you are putting a 36" fridge between 2 end panels the cupboard above is 36"
The height is the main question.
You can have a problem if the wall beside the fridge is more than 24" deep.
The cupboard above is still 36" with a scribe filler on the side to allow for out of plumb wall or molding at the floor or what have you.
Old 08-14-2018, 05:53 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 2,004
Best to check what the fridge manufacturer recommends for clearance. Many fridges, but not all, vent at the bottom. Good advice about making sure the door(s) open wide enough for proper access.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 08-15-2018, 08:28 AM   #5
Rewards Points: 104
Back clearance recommendation is 1", but I might do a little more to make it easier for waterline and electrical. I understand your point about the doors but I've already accounted for that.
All I'm really asking is if there's a rule of thumb for putting an appliance like this into an enclosed area with regards to the WIDTH. Appliance with PLUS 1/8" on each side seems about right to me, or would this be too snug?
Old 08-15-2018, 08:39 AM   #6
Rewards Points: 104
Well, my plan was to have the fridge stick out from the wall at the point of the door hinge which I think will allow 180 degree swing for each of side by side doors. In this case how much room would I need on either side of the fridge? (I've got the manufacturer specs, but I'm building the space for it to go ahead of time)
Old 08-15-2018, 03:50 PM   #7
Speaking personally, I would allow 1" more than the width of the Fridge. If space is tight or that is going to cause problems, I might cut tit to 1/2" if I had the Fridge on site for measuring.
Colbyt
Area off kitchen and room two steps down Sjsmom Interior Decorating 1 07-18-2015 12:12 AM
Choosing a Color Scheme For Your Room Micheal11 Interior Decorating 0 08-10-2012 10:03 PM
Theme for rec room area dinosaur1 Interior Decorating 7 07-03-2012 10:58 PM
Living Room/Dining Room Combo tklysen Interior Decorating 2 11-29-2011 07:09 AM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
