How To Level Basement Shower Base - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-08-2016, 09:12 PM   #1
jkk
Rewards Points: 329
How to level basement shower base
The floor under this acrylic shower base slopes ~1/2" from rear to front of 32x60 shower base that is going on top of concrete floor. Can I level this with self leveling cement? Or does it have to be mortar?
jkk is offline   Reply With Quote
Old 07-09-2016, 07:45 AM   #2
Retired Moderator
Rewards Points: 7,174
Re: How to level basement shower base
Best to use masons mortar----
Will the lip of the pan end up above the floor?
Will your tile hide the gap?
Old 07-09-2016, 08:29 AM   #3
jkk
Rewards Points: 329
I will check today
Old 07-09-2016, 10:18 AM   #4
Rewards Points: 172
Shower floor is supposed to slope, toward the drain. Leveling is done on the base frame and since the whole base may be flexing/twisting or just manufactured as such, you need to balance the frame level with the drain slope. Mortar bedding need to be on the dry side so that it holds its shape while setting and doesn't shrink. Also careful the bed doesn't deflect the shower base.
carpdad is offline   Reply With Quote
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 11:20 AM
Basement shower plumbing question. medicmike Plumbing 5 01-28-2012 05:40 PM
How do you make a shower base for a oversized shower nateyro Kitchen & Bath Remodeling 4 01-17-2012 10:39 PM
Older basement shower needs remodel. Questions about showers and concrete blocks. speedster1 Remodeling 6 01-28-2010 03:55 PM
Basement shower install howto greight Building & Construction 4 04-13-2009 05:19 AM
