How To Fix Tiling Mistake - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-25-2015, 09:25 PM   #1
Rewards Points: 396
how to fix tiling mistake
when putting the bottom wall tile up against the floor I forgot to set a spacer between the floor because I had a piece of plywood down to protect the floor.
Either way, I need to get a gap in there so I can put some grout in. It's outside the shower but right outside the shower so it's not unreasonable to expect some water will get to the crack and I'd like to make sure it's actually grouted.
Idea's? Can I use a dremel oscillating tool to trim off the tile? the tile is travertine if that helps at all. Also, it's like a 2 inch piece of tile I actually have to trim, so it's not that much.
If I can use the oscillating tool, is there a certain head for it that would be best?
MLMIB is offline   Reply With Quote
Old 10-25-2015, 09:38 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 748
If I'm following what you're saying, you do not want grout in there. Caulk is the right product. If you could post a pic it would be helpful.
Sounds like the outside of the shower curb, yes? Is the bathroom floor finished yet? Wooden or slab floors?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 10-25-2015, 10:33 PM   #3
Rewards Points: 396
Jaz
right outside the shower, floor is finished. I'm fine with caulk instead, but I think I still need to create the indent for the caulk to live.
Pictures... (first one zoomed, second one back.)
Old 10-25-2015, 11:13 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 748
Either leave it alone and caulk it, or remove the one piece and cut off ⅛".
Jaz
Old 10-26-2015, 05:47 AM   #5
Rewards Points: 396
Either leave it alone and caulk it, or remove the one piece and cut off ⅛". Jaz
What's a good tool for removing it?
I'm assuming the oscillating tool will break up the thinset without breaking everything?
Old 10-26-2015, 08:04 AM   #6
Rewards Points: 17,884
Something sure looks really wrong there.
Sure looks like your trying to install that tile right over OSB!
Where's the 1/4" tile board.
Old 10-26-2015, 12:36 PM   #7
Rewards Points: 396
Originally Posted by joecaption
Something sure looks really wrong there. Sure looks like your trying to install that tile right over OSB! Where's the 1/4" tile board.
The blue plywood is just there to protect the floor. Outside the shower it's over drywall for a short bit.
Old 10-27-2015, 11:10 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 748
Joe thought your bathroom floor tiles looked like OSB, and he's right, looks a lot like it from here.
Jaz
Old 10-29-2015, 09:17 PM   #9
Rewards Points: 5,680
The floor tiles are the same as the wall tiles, and they do look a little like OSB, but clearly they're tile.
As for the original question, if you don't like the look of the lack of gap at the bottom of the tile, then pry out the tile (for example with a large screwdriver). Scrape off the thinset from the wall if some stays behind. Cut a new piece of tile about 1/8" shorter than that one. Reinstall the tile. Caulk the gap with the matching caulk from the grout manufacturer.
jeffnc is offline   Reply With Quote
Big Tiling Mistake RomanDesign Tiling, ceramics, marble 7 09-09-2012 10:23 PM
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
Rookie ceramic tiling mistake! idlewatcher Flooring 18 12-20-2011 07:16 PM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 06:15 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
