How Do I Replace Existing Bathroom Vanity? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 10-28-2018, 12:49 AM   #1
Rewards Points: 755
How do I replace existing bathroom vanity?
I would like to replace my existing bathroom vanity. The tile doesn't go underneath the vanity and I would like to preserve the tile. The width of the vanity is 52 inches. 17 3/4 inch depth. That is measuring the base.
Would I search for 52 width x 18 inch depth? If you look at the photos, the tile was cut to accommodate the vanity. I don't have any additional tile, so wondering if I would buy something to fit over the tile, or just inside the tile.
How do I replace existing bathroom vanity?-20181027_150140.jpg   How do I replace existing bathroom vanity?-20181027_150312.jpg   How do I replace existing bathroom vanity?-20181027_150151.jpg   How do I replace existing bathroom vanity?-20181027_150115.jpg
greentrees is offline   Reply With Quote
Old 10-28-2018, 12:57 AM   #2
retired framer
Rewards Points: 18,492
Re: How do I replace existing bathroom vanity?
Vanities are 22" deep on top the measurement at the floor could be a crap shoot but you can just add would to the kick to make it work.
The trim on the right is a scribe strip. You shape that to fit the wall when the wall isn't straight. So the scribe strip could be wider if you needed to move the unit a little to hide some flooring.
Hopefully that helps.
Old 10-28-2018, 04:54 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
Vanities also come with 19" deep tops, the vanity box is 18" deep. 52" wide is not a standard width, I suspect yours was custom made ( and the exposed plywood end grain on the toe kick seems to confirm that). I would have a replacement made at a cabinet shop.
Sent from my RCT6213W22 using Tapatalk
MTN REMODEL LLC likes this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 10-28-2018, 11:23 PM   #4
Rewards Points: 755
Is the vanity normally separate from the base? So I could move the base, but keep the vanity in the same location. The reason is because the vanity will touch the wall, so can't move that part if I needed an inch.
The depth is 18 inches. I am curious if there is tile beneath the vanity. Is there an easy way to check? Notice in the photo there is a vent, so I assume there is a floor vent in the middle of the vanity floor, probably next to the back wall.
How do I replace existing bathroom vanity?-20181027_150219.jpg   How do I replace existing bathroom vanity?-20181027_150216.jpg   How do I replace existing bathroom vanity?-20181027_150201.jpg   How do I replace existing bathroom vanity?-20181027_150156.jpg
Old 10-28-2018, 11:33 PM   #5
retired framer
you should be able to remove the vent and sneak a peek.
The problem is you buy the cupboard to the size of the box and there are no set rules to the size of the kick under it, but you can always add to the kick.
Old 10-30-2018, 10:50 PM   #6
Rewards Points: 755
I was able to remove the vanity. There was some issues with the screws and back panel. I have the measurements of the base in the photos. I would think this is the original vanity that came with the house (1981). And the tile came in later. That heating vent is a bit unusual, but I guess it works.
Now that I have the base measurements, do I go to a store and have a vanity custom made, or can I order a vanity online, have it delivered, and hire a carpenter to install? If I order online what is an appropriate dimension to order.
Thanks.
How do I replace existing bathroom vanity?-20181030_184702.jpg   How do I replace existing bathroom vanity?-20181030_184708.jpg   How do I replace existing bathroom vanity?-20181030_184725.jpg   How do I replace existing bathroom vanity?-20181030_181007.jpg   How do I replace existing bathroom vanity?-20181030_180906.jpg
Old 10-30-2018, 11:03 PM   #7
retired framer
You can get away with a 48" cupboard if you can't find one to fit. Just order a filler panel to go with it.
Old 10-30-2018, 11:56 PM   #8
Rewards Points: 755
If I buy a 48 inch cupboard, then I would put a filler strip next to the wall (next to the door) of 4 inches?
Nealtw likes this.
Old 10-31-2018, 12:16 AM   #9
retired framer
If the base will come off the old vanity save it you may be able to use it with the new one.
Old 10-31-2018, 07:16 AM   #10
Rewards Points: 7,188
You may not find a vanity exactly the size that you had before, but if you do a search, you will find quite a few at 54" - 55" length.
SPS-1 is online now   Reply With Quote
Old 10-31-2018, 07:37 AM   #11
retired framer
It is already to close to the toilet.
Old 10-31-2018, 07:57 AM   #12
Guapo
Rewards Points: 11,950
BTW, it's not just the tiles that are important. If the new vanity has drawers in it, make sure that the drawers clear the pipes coming out of the wall.
Nealtw likes this.
Guap0_ is offline   Reply With Quote
Old 10-31-2018, 07:59 AM   #13
retired framer
And the door trim.
Guap0_ likes this.
Old 10-31-2018, 11:40 PM   #14
Rewards Points: 755
I am hoping the center of the vanity is empty to accommodate the piping.
The heating vent is more of an issue. I am not sure the vanity would have an open area on the bottom that I can cut into for the vent.
I was thinking a vanity with legs might work so it clears the vent. But I would have to attach a front and side panel to hide the plywood underneath. Not sure how simple that would be.
Old 11-01-2018, 07:26 AM   #15
Guapo
It appears that the vanity in post #14 will clear the pipes in post #6. What is the vent venting?
Bathroom - Plumbing for downsized vanity? weekendscrub Kitchen & Bath Remodeling 4 06-23-2017 12:17 PM
Wiring Scheme for Bathroom Vanity Lights DAKRO Electrical 5 01-17-2012 02:21 PM
How to build/attach wall hung bathroom vanity NewHomeDIYGuy Carpentry 13 12-28-2011 02:17 PM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 12:37 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
