How Do I Finish Outside Corner Hardiboard To Drywall ? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-02-2017, 09:38 PM   #1
Demolition Mode
Rewards Points: 129
Send a message via Yahoo to HandyDave
How do I finish outside corner Hardiboard to drywall ?
I am perplexed how to Finish the corner where the drywall meets the hardiboard before I put tile on. HELP PLEASE
Apologies for the sideways pic.
HandyDave is offline   Reply With Quote
Old 02-02-2017, 09:48 PM   #2
Super Moderator
Gymschu's Avatar
Rewards Points: 6,758
Re: How do I finish outside corner Hardiboard to drywall ?
Tile like you normally would to that unfinished edge then install matching bullnose? Then treat any gap left over as a regular drywall joint and finish with tape and mud.
"In the heat of battle, my father wove a tapestry of obscenity........."
Gymschu is online now   Reply With Quote
Old 02-02-2017, 10:01 PM   #3
Demolition Mode
Rewards Points: 129
I should have added This is the first time I have ever tiled
Old 02-02-2017, 10:17 PM   #4
Super Moderator
Gymschu's Avatar
Gotcha, HandyDave. I've never tiled walls, only floors. My assumption, and, it could easily be wrong, would be that you also could finish that corner like a normal drywall corner but use mortar/thinset instead of joint compound for the Hardie board side, and, regular joint compound on the drywall side. I suppose the problem could be that you create a corner on the hardie side that isn't truly flat causing a problem with the laying of the tile.
Old 02-03-2017, 05:59 AM   #5
Demolition Mode
Rewards Points: 129
Originally Posted by Gymschu View Post
Gotcha, HandyDave. " use mortar/thinset instead of joint compound for the Hardie board side, and, regular joint compound on the drywall side. I suppose the problem could be that you create a corner on the hardie side that isn't truly flat causing a problem with the laying of the tile.
That was my thought exactly! AND the problem it created when putting a corner piece on. It simply will not be flat.
Old 02-03-2017, 06:05 AM   #6
Demolition Mode
Rewards Points: 129
Hope this helps now that i got it orientated the proper way
Cement Board not Level in corner and between trans to drywall macdonnie Tiling, ceramics, marble 1 07-09-2015 09:29 AM
Drywall Pocket Door Wall Near a Corner TeeRiddle Drywall & Plaster 2 05-16-2015 04:30 PM
drywall tape or metal corner detaching TomMiller Painting 7 03-14-2013 10:08 PM
Cost to finish drywall? Pricing formula? fastmike22 Drywall & Plaster 2 02-13-2012 11:18 AM
Close off a doorway with drywall that has corner bead. Remove or mud over? cmgraue Drywall & Plaster 4 02-01-2012 03:00 PM
