Historic Home Tiny Bath Remodel! - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 07-15-2017, 01:31 PM   #16
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Re: Historic home tiny bath remodel!
If we are on the back side of the wall and your bathroom is on the other side, yes, I would deep six all the plaster and lath and go back with sheetrock/cbu depending on the use of the wall.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 07-15-2017, 02:27 PM   #17
Rewards Points: 129
Send a message via AIM to stiksandstones Send a message via Skype™ to stiksandstones
Yeah, photo is taken inside the closets (it was a coat closet at one end, and my daughters closet at the other) looking at the backside of bathroom wall.
Ok, im gonna tear out the drywall/lathe crapshow and reframe that entire wall.
jlhaslip likes this.
stiksandstones is offline   Reply With Quote
Old 07-15-2017, 05:48 PM   #18
Naildriver
chandler48's Avatar
Rock and roll. That's the best way to do it. Clean slate do what you need to do without having to make do with someone else's framing.
Larry......
Old 07-15-2017, 09:25 PM   #19
Rewards Points: 129
Ok, whole wall is gone, gonna try and frame this thing before nightfall...I assume I wanna frame the shower doorway/entry like this? http://www.finishabasement.com/const...or-opening.gif
Old 07-15-2017, 09:29 PM   #20
Rewards Points: 129
Dilemma is figuring out how HIGH/TALL my shower entry opening/door will be. Our plan is to eventually put a slider door, barn door style (would save us room from a swinging door-being our bathroom is so small), SO i'd have to frame this knowing WHICH door I will put on it eh? crap.
Old 07-16-2017, 05:47 AM   #21
Naildriver
chandler48's Avatar
With a barn door for the shower, how will you contain water splash? You could use the barn door, but would need a shower curtain, making the barn door redundant.
Larry......
Old 07-16-2017, 11:49 AM   #22
Rewards Points: 129
https://s-media-cache-ak0.pinimg.com...943cd7175e.jpg
Old 07-16-2017, 12:03 PM   #23
jlhaslip's Avatar
Rewards Points: 708
I would not use a header at the door opening.
Steam will build up inside the shower and the potential for problems is increased.
Having said that, I hope that is not a load bearing wall location or else you will need to get fancy with the transfer of loads across that space.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 07-16-2017, 12:43 PM   #24
Rewards Points: 129
I was thinking about putting a exhaust fan in the shower stall, electrician came out and said the way my crawl space is, close proximity to venting, it would be super easy....
As for the 'load bearing' wall, I assume you mean the large newly framed part (photo) I posted? That will get 16" OC 2x4's, and I left the inner and outer most original studs as they are in immaculate condition-those were also old 4x4 posts.
Old 07-16-2017, 12:48 PM   #25
Rewards Points: 129
Have not nailed these (shower entry) down, still trying to figure it out....and the other image of the 2 studs on the floor is the beginning of the shower stall walls (Not nailed down either) as I am baffled how to figure out the old remaining wall and how my new shower stall will butt up to that.
Historic home tiny bath remodel!-screen-shot-2017-07-16-10.44.55-am.jpg   Historic home tiny bath remodel!-screen-shot-2017-07-16-10.46.06-am.jpg
Old 07-16-2017, 01:51 PM   #26
Rewards Points: 129
what I mean on the shower stall framing, I am assuming i need to put studs/support in this vacant area?
Old 07-16-2017, 02:15 PM   #27
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,274
A 2x6 behind the last 2x4 will leave 1" sticking out each side for drywall/backer board.
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
Old 07-16-2017, 03:18 PM   #28
Rewards Points: 129
The 'vacant area' I pointed out, is all along that OLD wall, the old lath plaster wall-those studs are 2x3.25 old oak, I can't get a 2x6 in there...not to mention the old plaster 'keys' spilling out between the lath adds to the loss of space.
Old 07-16-2017, 03:25 PM   #29
Rewards Points: 129
Could I just toe nail in some 2x4's, to the existing old studs, to give the NEW shower stall something to attach to?
like so
Old 07-16-2017, 03:30 PM   #30
123pugsy's Avatar
You can block up any way that works. I thought you would be screwing your drywall/backer to the existing studs.
A 2x6 on it's flat behind the 2x4 would give a screwing block. So the 1-1/2 way, not the 5-1/2 way into the existing cavity.
The Following User Says Thank You to 123pugsy For This Useful Post:
stiksandstones (07-16-2017)
No vent stack in 1'st floor 1/2 bath. Blame home inspector? Hennessey Plumbing 54 03-04-2014 08:50 PM
Master Bath Remodel - Need Advice meth Building & Construction 8 12-07-2010 05:31 PM
Ricks bath remodel - please help RICK430 General DIY Discussions 1 05-19-2009 09:36 PM
Increase counter height on bath remodel sharisavage Remodeling 4 01-22-2007 11:44 AM
