Hinges Stuck To Doors - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-08-2014, 02:55 PM   #1
Rewards Points: 84
Hinges stuck to doors
I'm trying to cheaply update a kitchen by painting the crappy cabinets, but I've run into a problem removing the hardware. It appears they stained and sealed everything with the hardware attached. I can get the doors off the cabinet face frames, but the wood below the hinge is unfinished. Not a major problem...
However, when I attempt to remove the hinge from the door itself chunks of the wood are being removed as they're stuck to the hinge. I don't really want to have to strip everything but we do want to replace the hinges and get a good paint job on what we have. The cabinet doors are oak plywood with trim on the front only, so the hinges are screwed directly to the plywood.
I've tried cutting around the hinges with a utility knife before we attempt to remove them, but it is acting as if there is a layer for finish between the hinges and the wood, and it's stronger than the plywood.
Suggestions?
jmyers63 is offline   Reply With Quote
Old 10-08-2014, 05:03 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Suggestions?
Heat the hinges with a heat gun. Don't blister the finish from the heat.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Startingover (10-14-2014)
Cabinet Door Overlay & Hinges Kitchencabinet1 Building & Construction 1 02-19-2013 06:38 PM
Replacing Doors in masonry wall mwpiper Project Showcase 17 05-12-2011 07:00 AM
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 09:32 AM
Hidden hinges for 1/2" doors patcrisp Carpentry 3 08-29-2009 08:14 PM
