High CFM Range Hood Install - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-11-2016, 05:34 PM   #1
Rewards Points: 153
high CFM range hood install
When installing high CFM range hood, the routing duct always should go up or flat, but never go downward??
also can I use dryer duct(lower elevation than range hood) to combine with my range hood duct? if so how do i prevent the exhaust from range hood split into dryer.
s002wjh is offline   Reply With Quote
Old 10-11-2016, 08:22 PM   #2
Rewards Points: 7,222
Re: high CFM range hood install
Hot air wants to rise, so if you slope it downwards, I would expect there would be more resistance to airflow, but if that is your only option, I don't see that as so terrible. If you slope down, and then up again, you are creating a trap, that will can fill with condensation. Stick to manufacturer's instructions and you should be OK.
Combining your dryer duct and your range hood does not sound like a good idea, for the reason you have suggested (plus dryer venting into your kitchen).
SPS-1 is online now   Reply With Quote
Adding range hood to 15A light circuit dman535 Electrical 1 09-15-2016 08:19 PM
Venting a range hood down thru the besement Amazer98 Kitchen & Bath Remodeling 12 01-23-2016 10:11 PM
Range hood install Zephyrg HVAC 1 08-14-2012 09:08 PM
Kitchen Range Hood Tryon HVAC 2 04-01-2012 05:01 PM
Range hood installation problem Lucas718 Appliances 4 08-16-2010 01:28 PM
