HELP! What Faucet To Fill The Bathtub? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By lenaitch
Old 02-18-2017, 08:29 PM   #1
Rewards Points: 22
HELP! What faucet to fill the bathtub?
Hello, I could really use some help. We are remodeling our bathroom and have a stand alone tub capable of holding 103 gallons. How many GPM does my faucet need to be? We are looking for a wall mount faucet since that is the design set up. Does anyone recommend one? Thank you!
00naomi00 is offline   Reply With Quote
Old 02-18-2017, 09:40 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,040
Re: HELP! What faucet to fill the bathtub?
You are asking an incomplete question because it doesn't have a time factor, as in in 'how many GPM does my faucet need to be to fill my tub in x minutes'. Regardless, GPM is governed by the pressure and volume of the supply. Depending on your location, you may have difficulty finding the GPM of a fixture without possibly contacting the manufacturer but I'll take a wild guess that they are pretty much all roughly the same. Differences might be found between mixing valves and traditional faucet-spout combinations.
Find one that looks nice and fits your budget and live on the wild side.
00naomi00 likes this.
lenaitch is offline   Reply With Quote
Old 02-18-2017, 09:45 PM   #3
Rewards Points: 22
My concern is that if I don't get the right faucet and end up with a rate of 2 or 3 GPM, the water in the tub would be cold before it was full enough to enjoy. I'm having a difficult time finding anything higher than 3.
Old 02-18-2017, 10:04 PM   #4
Usually Confused
lenaitch's Avatar
Assuming you branch supply is 1/2", that may be about as best as you can expect. Available flow is also affected by pressure at source and the length of the run.
Use more hot.
Water only from the shower head and not bathtub faucet nr54017 Plumbing 2 05-24-2013 12:16 PM
How to fix the bathtub faucet dripping? compiler Plumbing 10 03-07-2013 09:17 PM
Bathtub faucet won't stay depressed to direct water to shower head ferrugia Plumbing 13 02-27-2013 09:39 PM
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 11:24 AM
replacing 30 year old delta bathtub faucet markha Plumbing 2 11-06-2010 08:19 PM
