Help W/ Walk-In Shower/Bathroom Layout - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By nobbyv
Old 10-25-2018, 08:05 PM   #1
Rewards Points: 234
Help w/ Walk-In Shower/Bathroom Layout
Building a new house, acting as my own GC, and out of my league here: the bathroom layout calls for a drop-in tub in the upper left corner, and a walk-in shower in the lower left hand corner. There's a window that on the wall between the the shower and tub area. We've made a few changes from this layout, but this is the basic idea:
The area I'm wondering about is where the tub deck and the shower enclosure meet: we ended up having to move the shower head to where the "bench" appears on the plan above, and put the bench on the opposite side on the wall that butts up against the tub deck. My question is what do we actually do with that wall? We have a bench, so we'll have solid wall up 18" or so. But for the rest of that wall of the shower enclosure, what would you recommend? I'd love to do glass on the upper part of that wall, but am I rapidly moving from a price range of getting a "semi-custom" shower door to one where I'm going to need a full custom door company to build it? What's the approximate cost delta on something like that? 25%? 100%?
Thanks for any input!
nobbyv is offline   Reply With Quote
Old 10-26-2018, 02:41 AM   #2
retired framer
Rewards Points: 18,874
Re: Help w/ Walk-In Shower/Bathroom Layout
The usual program is to build the tub surround including the bench in the shower, Tile everything and then add the glass surround .
The bench absolutely needs a slope and better waterproofing and anything else .
It should semi separate if that makes sense so that inside the shower you have room for the slope and a membrane below the tile.
I have repaired a few of these and that is the leaky spot every time.
Old 10-26-2018, 04:46 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,692
Another solution would be to add an after market bench. I have installed these for people with disabilities and they really like them. Some will lift to a flat position so they are out of the way. The ones I have installed have teak slats so they are "homey", but waterproof.
Tough question here, so don't be offended. Is that spa and all the windows going to be to your liking? Remember if the windows come down to the level of the tub, they must be tempered. Looking out also means looking in, and occluding windows completely is not 100% in most cases. We are located adjacent to the USFS area so only bear and deer look in, but in many urban settings I can see it to be a detriment.
Without the spa and one window you could have a nice walk in shower WITHOUT a door and all the cleaning associated with it. Properly placed controls could direct water away from the opening. Just some points to ponder.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 10-26-2018, 07:13 AM   #4
Rewards Points: 234
The windows are already in, and they are tempered. This bathroom is on the second floor of the house, which sits on 7 acres, so we also will have views of little more than deer, turkeys and trees.
chandler48 likes this.
Kitchen/Dining Room Layout JRDepew Remodeling 2 01-23-2014 12:04 PM
Assessing value of layout changes mbianco General DIY Discussions 6 07-21-2012 11:48 PM
Bathroom layout to fit rough in? bryanl Remodeling 6 09-21-2011 08:02 AM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
