Help! Toilet Flange Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-17-2015, 09:45 PM   #1
Rewards Points: 2
Help! toilet flange question
Hey Everyone, I'm new to plumbing so I could use some help. I have a 1964 house with crawl space and I am trying to remodel my bathroom.
The bathroom had old tile with about 2" mud set. I have removed the mud and tiles.
My toilet however is now causing me problems.
When I removed the toilet I found it had been leaking due to a crack where the cast iron flange (?) connects to a lead drain pipe. (The lead pipe connects with a cast iron closet drain pipe about a foot down- this looks to be okay). So I am wondering how to fix the flange?
Can I repair the pipe somehow?
Should I get a new flange?
I plan on installing plywood then backerboard then my new tiles. I am worried that the height of the toilet flange will be too high since it was already 3/4" higher than the old tile.
Any suggestions would be appreciated.
*** Notice the crack in second photo
1stimediyer is offline   Reply With Quote
Old 07-17-2015, 10:04 PM   #2
Rewards Points: 17,884
Whole lot easier to do what your doing if you snap off the old drain below the floor.
Install a hubless connector and run a new piece of PVC and new flange once the subfloor and tile is done so the flange is sitting even with the finished floor.
Old 07-21-2015, 09:39 PM   #3
Rewards Points: 225
Basically, what he said. Also, show some pictures with the mud and everything removed, it would give a better idea how to help, and if you could take a photo underneath. It could be a pretty simple fix, but if there is a crack anywhere, you want to replace that part without a doubt.
scyarch is offline   Reply With Quote
toilet flange question... edselsouth1 Plumbing 2 05-01-2013 11:13 PM
Question about toilet flange darius Plumbing 13 05-15-2012 11:16 PM
Changing out carpet for tile - toilet flange? M3 Pete Plumbing 4 02-16-2012 10:20 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
Toilet flange question. speedster1 Plumbing 4 04-07-2010 10:30 AM
