Help Please - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-18-2016, 07:19 AM   #1
Help please
Hired a " proffesional tile person"
Come to find out he has installed LFT versabond as the mudbed, thankfully that all he did before I fired him
My question is has anybody removed thinset LFT that was installled onto a shower pan
Look @ versabond website and it said it doesn't adhere well to plastic
My shower pan is brand new and I know it was not leaking prior to having the incorrect mudbed installed
Clearly I am trying to same the pan so the correct mudbed can be installed
Everything else is done and redguarded 3 times, so I would hate to break it down and to install a new pan
Any help is appreciated
Thank you
Morten
Thedane is offline   Reply With Quote
Old 12-18-2016, 09:50 AM   #2
Rewards Points: 6,887
Re: Help please
Thinset on a plastic surface should come off real easy with a wet sponge.
Should you choose or need to scrape use a wood or composite shim and not a metal putty knife.
With either method work small areas and remove the gritty residue often and gently.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 12-18-2016, 10:23 AM   #3
The "mud bed" made out of
LFT is between 1/2 and 1-1/2 thick
So I will have to chisel it out gently
Just wondering if it sticks to the shower pan
I am hoping it is coming out in big pieces?
Thank you
