Help ID This Thing In My Kitchen That Needs To Be Removed - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-19-2014, 01:01 AM   #1
Rewards Points: 323
Help ID this thing in my kitchen that needs to be removed
I have a forward facing kitchen that look into the living room. There's this thing, I have no idea what it's called, it's like a counter tops but sits above my kitchen sink. It's about 3 ft long and 1 1/2 feet deep.
I want it either removed or pushed back a few inches so when visitors are in the living room they brush up against it. Sorry I got no pictures to show.
johnv713 is offline   Reply With Quote
Old 08-19-2014, 01:06 AM   #2
Rewards Points: 323
A raised bar maybe? Does anyone know how to remove one so that i can push it back a few inches?
Old 08-19-2014, 06:33 AM   #3
Retired Moderator
Rewards Points: 7,174
Typically those are glued down---sometimes attached to a sub backer that is screwed---
Cut any caulking and pry it up a bit--see what is holding it in---
gregzoll (08-19-2014)
Old 08-19-2014, 01:09 PM   #4
Rewards Points: 323
I was thinking it may be held down with caulk. Maybe screws too cuz they seem pretty sturdy to me. thanks
Old 08-19-2014, 03:09 PM   #5
Rewards Points: 6,652
Commonly called a Breakfast bar. They are made to stick out, so people have an area over their laps, while sitting at it.
It all depends on the material that it is made of. If stone, it is held in place with Silicone based Caulk. If it is Formica, could be Carpenter's Nail glue.
Old 08-20-2014, 02:01 AM   #6
Rewards Points: 323
i think it's made of wood then the original owner put subway tiles on top. I know that looks hideous Im going to try to saw both sides that are touching the walls first then work the bottom.
The Following User Says Thank You to johnv713 For This Useful Post:
oh'mike (08-20-2014)
Need help in re-designing tiny 1920's kitchen! PiscesWoman Interior Decorating 21 04-30-2012 03:25 PM
2 Bathrooms and a Kitchen KevinACrider Project Showcase 16 10-31-2011 06:03 AM
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 01:17 PM
Kitchen reno, any better suggestions? mgarfield Remodeling 7 01-20-2010 03:37 PM
