Help With Enamel Kitchen Sink - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-13-2015, 03:47 PM   #1
Rewards Points: 119
Help with Enamel Kitchen Sink
Hello all,
My house was built in '51 and has the original cast iron enameled kitchen sink. In good shape but where the base for the faucet has sat for decades it is 'dirty'/discolored (if you remove the base).
The faucet needs changing and want to use the existing sprayer hole for a new under-sink filter system faucet. Meaning the new setup will not have a base plate, but be two individual faucets.
Anyone know how to get the enamel clean where the base plate has sat all these years? There is also a tiny bit of rust where the metal trim and sink meet, behind the faucet.
Thanks for any suggestions.
Trese is offline   Reply With Quote
Old 06-13-2015, 04:16 PM   #2
Rough Rooster's Avatar
Rewards Points: 390
I have good success with Muriatic acid. Dilute to half strength (pour acid into water) and use an old tooth brush to apply the acid. Will take quite a bit of refreshing acid on brush and rubbing stain/water deposit, but will amaze you how clean it gets.
Do have plenty of ventilation and DON'T breathe the fumes from this.
RR
Rough Rooster is offline   Reply With Quote
The Following User Says Thank You to Rough Rooster For This Useful Post:
Trese (06-14-2015)
Old 06-14-2015, 12:45 AM   #3
Rewards Points: 119
RR
Appreciate that! Will give it a go!
Washing machine making "glugging noise"; kitchen sink backing up; bad smells; UGH KDG Plumbing 5 01-04-2015 06:27 PM
Slow drainage and gurgling, overflow in kitchen sink daluu Plumbing 10 04-06-2014 10:29 PM
Kitchen Sink Venting pool Plumbing 1 02-15-2014 09:37 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
