Help - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-03-2010, 09:56 AM   #1
help
how do remove rust from caulking
mlang51 is offline   Reply With Quote
Old 11-03-2010, 03:35 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Remove the caulking.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
BigJim (11-03-2010)
Old 11-04-2010, 05:13 AM   #3
can be a time consuming job you will have to manually remove it, good luck.
Bobby_B is offline   Reply With Quote
Old 11-05-2010, 11:04 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Your caulk is rusting?!?
Maybe a pic or further description would be a good idea.
Old 11-05-2010, 11:26 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow it happens.
Actually what is happening more than likely is the water has a high iron content. The water gets into (or sits on) the caulk and oxidizes as it dries after each use. Hence: "rusty caulk". It's a common issue in some areas.
XXX
Old 11-05-2010, 12:19 PM   #6
Stuck in the 70's
Rewards Points: 12
Go figure. Learn sumpin new every day here.
Thanks Bud.
Old 11-05-2010, 12:27 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
XXX
Old 11-05-2010, 12:45 PM   #8
ccarlisle's Avatar
OR put some "CLR" or equivalent in an old spray bottle, spray a bit and see what happens. It should remove the rust. Are there rust spots elsewhere that would suggest/confirm you have iron in your water? like the toilet?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
