Hardibacker/Drywall Outsider Corner - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-26-2015, 11:43 AM
Rewards Points: 12
I'm redoing my bathroom and need help on how to approach the outside corner where the cement board will meets the drywall. I would like to have the tile go all the way to the corner. Should I install the greenboard all the way to the cement board? Should I use an outside corner? If so, what kind? Any thoughts or advice are welcome.
Hardibacker/Drywall Outsider Corner-fullsizerender-9-.jpg
kgpuzio is offline
Old 10-29-2015, 09:20 PM
Rewards Points: 5,690
It's really not clear from that picture and your description what you're doing. You have green drywall already installed, right? And you want to know what to do at the INSIDE corner??
jeffnc is offline
The Following User Says Thank You to jeffnc For This Useful Post:
kgpuzio (10-30-2015)
Old 10-30-2015, 05:23 PM
Rewards Points: 12
Thanks Jeffnc. The cement board is up (shown in picture). I am wondering how to install the greenboard (not up ... but will go over studs on right side of picture) and how to do the outside corner. For example, should I use a vinyl or metal corner? And, how should I fix that outside corner.
kgpuzio is offline
Old 10-30-2015, 05:49 PM
Tileguy
JazMan's Avatar
Rewards Points: 748
Thanks kgpuzio,
That was as clear as mud. That corner, every outside corner needs outside corner bead. Wet area, plastic.
Why is there concrete backer on that one wall, but gb where we see it? Hows about another pic from a few steps back, or a description of what this room is?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
JazMan is offline
Old 06-02-2016, 09:16 PM
Rewards Points: 83
Re: Hardibacker/Drywall Outsider Corner
I think that all the board you see is cement board, the lighting just makes it look a little green. I am currently having the same dilemma. Here is a picture of my install:
Do you put the plastic corner bead on and tile over it? Won't that telegraph thru the by changing the angle of the last tile in each row?
daxinarian is offline
Old 06-03-2016, 09:10 AM
That is definitely drywall and not cement board on the outer wall. The corner bead won't be a problem because the thinset will fill in any inconsistency in height.
jeffnc is offline
Tags
bathroom , cement backer , drywall , outside corner
crown molding fitting problem momof2labs Carpentry 16 10-15-2011 12:45 PM
Inside corner on small corner jburchill Drywall & Plaster 0 09-21-2011 10:08 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
