Grout And Sealer - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-13-2017, 08:58 AM   #1
Rewards Points: 892
Grout and Sealer
I plan to buy premixed grout for old 4" shower tiles. Only about a dozen small seams to repair. In case no one is available at store to advise me does anyone have recommendations?
Also I read grout should be sealed every few yrs. I doubt its ever been done. Any special sealer? These tiles almost butt up against each other. You can barely see the grout.
Startingover is offline   Reply With Quote
Old 08-13-2017, 11:15 AM   #2
Dave Sal's Avatar
Rewards Points: 1,176
Re: Grout and Sealer
I've used this grout sealer and am pleased with the results.
https://www.amazon.com/StoneTech-Hea...AD41KQQK15W9NN
Dave Sal is offline   Reply With Quote
The Following User Says Thank You to Dave Sal For This Useful Post:
Startingover (08-13-2017)
Old 08-14-2017, 09:27 AM   #3
Rewards Points: 892
Whats the difference in grout:
Sanded
Unsanded
Acrylic
Urethane
Maybe it doesn't matter since this is such a small repair.
Thanks.
Old 08-28-2017, 05:32 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 750
Assuming you meant 4 1/4" ceramic wall tiles, you need to use unsanded grout. I do not recommend pre-mixed grout unless it's one of the "special" high quality grouts.
Any sealer will help slow down moisture absorption, to make it easier to maintain. Sealer does not completely seal though.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 08-30-2017, 09:01 AM   #5
Rewards Points: 38
Im doing a similar project as you right now. While I have similar questions. One part of the project I do have figured out is using this stuff after the regrouting
http://www.homedepot.com/p/Custom-Bu...0HPT/205299503
It seals and recolors grout, so you can use it on the old grout as well to get the dirty old grout to match the new.
The best premixed stuff that is not epoxy seems to be fusion pro (from home depot), its a waterproof grout/sealent premix. no sealing needed after. The cons seem to be its thicker and dries faster than regular grout (you need to keep wiping with wet sponge while applying). I havent used it myself yet, waiting on the mfr to tell me how well it will bond with normal grout.
J_Sole is offline   Reply With Quote
does sealer as a grout release damage intended grout? MLMIB Kitchen & Bath Remodeling 0 11-05-2015 07:38 PM
ceramic tile grout sealer additive crankbait09 Flooring 9 01-12-2015 07:41 PM
Do I need two layers of grout sealer? sukhenkoi Kitchen & Bath Remodeling 5 01-14-2012 06:53 AM
Grout sealer recommendations? tzinho Tiling, ceramics, marble 0 04-07-2011 01:17 PM
Grout sealer advice turbomangt Remodeling 0 06-22-2010 08:38 AM
