Greenboard Or Hardie Backer For Non-perm Shower? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-01-2015, 05:51 PM   #1
Rewards Points: 81
Greenboard or hardie backer for non-perm shower?
I have a large room with water and drain access and am wanting ot put in a non-permanent shower. I have sourced a shower enclosure and base, as well as a pump for the drain water to pump it up and out through a drain. But in remodeling the room and getting it ready to do this I would like to make sure I do everything correctly.
My question is what to use for the walls? When I leave this place I will be removing the shower enclosure and will leave the walls in place. Do I use regular greenboard? Or would it make more sense to use hardie backer for the walls in the corner where the shower will go?
tunaman is offline   Reply With Quote
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 01:16 PM
Hardie backer board textured with thin set wildwort Tiling, ceramics, marble 14 11-21-2011 10:01 AM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
Damaged backer board during shower tiler removal, repairable? Bobster Building & Construction 2 10-06-2008 10:00 AM
installing greenboard above shower Hutch General DIY Discussions 2 02-29-2008 09:04 PM
