Granite Tile Backsplash For Wet Bar - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-15-2014, 10:39 AM   #1
Rewards Points: 117
Granite Tile Backsplash for Wet Bar
I picked up some 12 x 12 Absolute Black granite tiles (16 sq ft) for my mancave wet bar backsplash. I have a couple of questions about installing it.
  1. Is CBP OmniGrip max strength tile adhesive for marble and granite OK to use to set the tiles?
  2. What size grout lines is recommended?
  3. Non-Sanded (up to 1/8) or Epoxy grout? They both come in the charcoal color that I want to use.
Thanks!
tommyxv is offline   Reply With Quote
Old 05-15-2014, 10:46 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
  4. Thanks!
1.) I would recommend thinset and stay away from any of the pre-mixed tile adhesives. Some of them contain oils that can stain natural stone.
2.) That tile has a slight chamfered edge. A 1/6" grout space is common and so is 1/8". Your choice.
3.) Non-sanded standard grout would be my choice. Epoxy grout could be problematic on shiny granite and may smudge the surface and you may not be able to remove the smudges.
The Following User Says Thank You to Bud Cline For This Useful Post:
oh'mike (05-15-2014)
Old 05-15-2014, 10:52 AM   #3
Rewards Points: 117
Hi Bud,
Thanks for the quick reply. You're right, the tile does have a slight chamfered edge. Any particular thinset? I am going over painted drywall.
Thanks,
Old 05-15-2014, 10:56 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Scuff the paint and use a "modified" thinset. Those tiles have a backside that is super flat so I wouldn't use a trowel with a notch any bigger than 3/16" X 3/16" and comb the backs 100% with thinset.
Old 05-15-2014, 11:01 AM   #5
Rewards Points: 117
Thanks for the help and info!
Old 05-15-2014, 11:07 AM   #6
Rewards Points: 117
This OK for thinset and grout?
http://www.homedepot.com/p/Custom-Bu...MM50/100154560
http://www.homedepot.com/p/Custom-Bu...6010/100092922
Old 05-15-2014, 11:22 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The grout is a keeper.
The thinset shown is a "medium bed" type thinset. It will work fine but isn't necessary in your case. A "medium bed" thinset contains larger sand particles than regular modified thinset, that is the only difference. The medium-bed tends to lay-on thicker and won't smoosh down as much. In the case of a wall backsplash I would think a guy would want the tile to sit as close to the wall as possible since edge-trim may be an issue otherwise. It's your call - either is fine.
Old 05-15-2014, 01:18 PM   #8
Rewards Points: 117
How about this for the thinset?
http://www.homedepot.com/p/Custom-Bu...SG50/100162542
It's poly modified or should I be looking for latex modified?
Old 05-15-2014, 03:03 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That'll work fine!
Poly modified/latex, same-o same-o, for your purposes.
Old 05-15-2014, 03:12 PM   #10
Rewards Points: 117
Now I have the correct products to do the job correct. Thanks again for your help.
Old 05-15-2014, 03:14 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Glad to help. Good luck with your project.
tommyxv (05-15-2014)
Old 05-29-2014, 08:29 AM   #12
Old School
cabinetman's Avatar
I've always used cement board to install tiles on counter tops and back splashes. When I first started to install kitchens, I watched the tile guys do their thing. This is what they did. Maybe they were wrong, but their contention was that the drywall surface is just a paper, and cement board would provide a better substrate. They installed with a 'fortified thinset-polymer modified', no spacing, and used a non sanded grout.
cabinetman is offline   Reply With Quote
Old 05-29-2014, 02:45 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There is nothing wrong with installing tile on drywall in this case, cement board just isn't at all necessary.
XXX
Old 05-29-2014, 03:53 PM   #14
Old School
cabinetman's Avatar
Any problems with using cement board?
Old 05-29-2014, 05:04 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nope, other than more cost needlessly and the seams are a little harder to deal with.
XXX
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 11 01-03-2018 05:33 PM
18x18 Tile backsplash mumof5 Remodeling 3 06-10-2012 07:10 PM
removing granite backsplash momof2labs Building & Construction 2 03-14-2010 05:10 PM
New granite in existing construction, I want to keep my backsplash nam11b Building & Construction 5 04-15-2009 01:50 PM
granite floor tile which mortar? diy888 Flooring 10 01-23-2009 07:20 AM
