Granite Countertop Templating - Best Practices? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 02:41 PM   #1
Newbie Bill
Rewards Points: 534
Granite countertop templating - Best practices?
Hey Gang,
We have the granite company coming on Friday to template for our kitchen counter tops. My question is do I remove the old countertops or leave them on?
I spoke to the templaters and was told they are now using a new laser template system that makes the process much more accurate, even leaving the existing countertops on. However, their literature says:
We recommend that the subcontractor remove all old countertops prior to template. Should you choose to leave existing countertops in place we are not liable for inconsistent overhangs or gaps. Any cabinet modifications or extra support needed are the responsibility of the subcontractor. Company has the right not to install product on unleveled or improperly supported cabinets.
Installation of new countertops is optimized when walls and cabinets are properly prepared for installation. This includes, but is not limited to structurally sound, level, and square walls and cabinets, lack of which may affect installation and seem fit, or inconsistent coutertop overhang.
Turn around time is 3 to 4 weeks and we can't be without the sink that entire time so I would have to lay the old countertops back on the cabinets and reinstall the old sink.
I'm sweating buckets just thinking about how to get the old ones off as it is u shaped and will require some cutting. And then to hook the plumbing back up has me petrified.
So please share your thoughts.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 04-06-2010, 03:47 PM   #2
Remodeling Contractor
leave them on as long as you have level counter now and the edge overhang is even. If not then remove so these issues can be fixed.
Old 04-06-2010, 03:50 PM   #3
firehawkmph's Avatar
Rewards Points: 2,454
Bill,
Why don't you just cut the counterop a few inches on both sides of the sink, leaving enough for it to straddle the sink base. Take the rest off and throw it away. You could use a jigsaw if you are carefull and not cut the cabinet fronts. I would think you could even leave the small piece with the sink in place if they are templating with a laser. Worse comes to worse, disconnect the supply lines and tailpiece and lift it off.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 04-06-2010, 03:53 PM   #4
Originally Posted by firehawkmph View Post
Bill,
Mike Hawkins
why do you think it needs to be removed? 3 weeks with no counters... you must not cook!
Old 04-06-2010, 04:13 PM   #5
Newbie Bill
Rewards Points: 534
If I can cut the counters without too much carnage, I can just lay them back on the cabinets until the granite is installed.
My biggest issue with cutting the counters is I have the attached back splash (similar to what is in the photo).
What kind of saw can I use to cut the back splash without taking the wall with it or do I cut the backsplash off the countertop first? And what pray tell would I use to do that?
Bill
Old 04-06-2010, 04:19 PM   #6
Bob,
Maybe because he stated he didn't want to be without the sink. If he wants to put the countertop back in sections and let them set in place, that would be fine and his choice. And for your information, I do cook!
Mike Hawkins
Old 04-10-2010, 01:58 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What kind of a fly-by-night countertop company wouldn't deal with these issues for you with the least disruption to your lives?
XXX
Old 04-10-2010, 02:16 PM   #8
Newbie Bill
Rewards Points: 534
Countertops removed, templating done, and counters and sink reinstalled until granite arrives.
Sorry Bud, but I didn't want to have to pay extra to have the granite guys come in unhook plumbing, remove old countertops, Template, then reinstall old plumbing and countertops. So I did it myself.
Probably completely unnecessary as you said earlier as they could have templated with old countertops on. But I want perfection.
Thanks for you help.
Bill
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 11 01-03-2018 05:33 PM
Creative uses for countertop granite scraps Part 2!! Rhizzlebop General DIY Discussions 8 03-31-2011 09:06 AM
Granite tile for countertop speedster1 Remodeling 18 12-16-2009 07:16 PM
Countertop - Epoxy Granite over Laminate sdrachel Remodeling 1 09-19-2009 06:15 AM
Creative uses for countertop granite scraps 1 Rhizzlebop General DIY Discussions 10 06-01-2009 07:18 AM
