Grab Bar Installation. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By chandler48
  • 1 Post By DR P
Old 01-24-2018, 05:08 PM   #1
Guapo
Rewards Points: 11,950
Grab bar installation.
Of course, the best way to install a grab bar is to screw it into the studs. However, the length of a grab bar doesn't always match the 16" OC stud spacing. In that case, are plastic anchors the next best choice? What else is recommended?
Guap0_ is offline   Reply With Quote
Old 01-24-2018, 05:18 PM   #2
retired framer
Rewards Points: 18,698
Re: Grab bar installation.
watch the video on this page.
https://www.homedepot.com/p/Stud-Les...-RES/301294167
Old 01-24-2018, 07:48 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,640
You can always install them at an angle where the caps will fall over a stud. Pre-planning always helps to have 2x12's across at 34" center AFF in a shower or tub.
You are right, though, I noticed none are ever in 16" increments. All are 12", 24", 18" etc.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 01-24-2018, 07:50 PM   #4
Guapo
Neal, I'll watch that video ASAP
Chandler, the last customer didn't want the bar on an angle.
Old 01-25-2018, 05:21 AM   #5
Naildriver
chandler48's Avatar
One more option if there is a repairable wall on the opposite side of the wall, you can go in and install support boards, then patch and paint the wall and install the bars normally.
dd57chevy and mark sr like this.
Larry......
Old 01-25-2018, 06:20 AM   #6
Peace be with you
DR P's Avatar
Rewards Points: 1,860
moen makes 16" bars
even have their own anchoring system for retrofit
because we all know those studs never fall out where we need them...
old school was to router/dress up a 1X4 (or 1x6) & pre-paint same as wall color
counter-sink two strong screws per stud through wall board
optional: I paint screw heads or they could be concealed
Stud spacing & length of bar dictates how long a board is required...
Obviously not for inside tub/shower but Takes less time than opening up walls
Edit: no way I'd use plastic plug-in anchors
Peace
MTN REMODEL LLC likes this.
DR P is offline   Reply With Quote
Old 01-25-2018, 07:21 AM   #7
Guapo
Neal, I finally watched that video. I like that grab bar fastener & I'll use it next time. Of course, I'll probably get lucky & hit the stud.
Dr P, Most of the grab bars that I install are inside the tub/shower. Moen shouldn't be the only people who manufacturer 16" grab bars but I guess they are.
Need help installing a grab bars on already established holes Spend Drywall & Plaster 9 01-21-2015 04:07 PM
Victim of improper Roofing installation. tbirleffi Roofing/Siding 9 06-06-2013 10:45 AM
Veneer Brick Installation jefsboys Remodeling 3 11-01-2012 06:42 PM
Kitchen and Living Room Installation bejscott Insulation 1 08-10-2012 12:18 PM
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
