Glass Mosaic Tile Backsplash - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-08-2014, 11:45 AM   #1
Rewards Points: 85
Glass mosaic tile backsplash
Hi There.
Never worked with this type of tile before and I had a couple questions.
First, what do you suggest for exposed ends? One side of the backsplash will end at the end of the cabinets but the wall continues. Same thing near window where there will be no cabinet above the tile.
My other question is the easiest way to cut out the outlets that are on the wall. I plan on using a wet saw, and just don't know the best way to cut out the outlet of it falls in the middle of a tile.
Any other thoughts/suggestions are welcome and appreciated!
joshs is offline   Reply With Quote
Old 12-08-2014, 05:28 PM   #2
Retired Moderator
Rewards Points: 7,174
Metal tile trims are the simplest way--they come in lots of shapes and colors---
An angle grinder with a diamond blade is helpful---wet cutting of mesh back tiles often causes the whole sheet to come unglued--if you use the wet saw--cut out the tiles from the mesh before using the wet saw---wedge spacers will be needed--be sure to have some on hand.
Old 12-09-2014, 10:40 AM   #3
Rewards Points: 85
Thanks! I looked at the metal trims. What would be the best way to cut this?
Old 12-09-2014, 04:09 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Hacksaw.
XXX
Old 12-14-2014, 08:13 PM   #5
Rewards Points: 85
One more question for this install. I will be leaving the existing 5 inch backsplash from the countertop and adding tile above it. The countertop is a laminate countertop, and the top of the backsplash is caulked. Should I remove the caulk before adding tile? Also, should I grout the gap between the laminate and the tile or try to keep grout out and caulk the space in between?
Thanks!
Old 12-14-2014, 08:39 PM   #6
Retired Moderator
Remove the caulk before you start---the junction between the counter and the back splash needs caulk after tiling--that counter will move a bit with the seasons--which will crack grout.
Old 12-14-2014, 08:56 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 9,258
This is an example of what Mike is talking about. I just used some in my downstairs bathroom. In my case I used real SS at $72/stick. But man, does it look good. As soon as I get from Israel I'll post some pics of it.
HD carries the stuff
Here is a link to the Schluter products.
http://www.schluter.com/139.aspx
ddawg16 is online now   Reply With Quote
Old 12-14-2014, 09:16 PM   #8
Rewards Points: 85
Thanks everyone!
The Following User Says Thank You to joshs For This Useful Post:
oh'mike (12-15-2014)
Mastic or thinset for decorative glass tile mosaic? gtothek Kitchen & Bath Remodeling 1 09-28-2012 06:33 PM
Sealing grout on a glass tile mosaic backsplash? smithers76 Tiling, ceramics, marble 1 05-08-2011 06:44 AM
adhesive back glass mosaic tile dzy Kitchen & Bath Remodeling 1 04-29-2011 11:34 AM
What can I use to adhere mosaic glass tile (sheets) to particleboard? DIYLuvr Tiling, ceramics, marble 9 01-11-2011 12:30 PM
