Gel Stain On Existing Cabinetry - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mark sr
Old 04-24-2019, 10:37 AM   #1
Rewards Points: 36
Gel stain on existing cabinetry
Does anybody have experience using General Finishes gel stain on their cabinets? I have some really nice oak cabinets with an old honey oak finish that I want to update with a darker stain. I want to keep the grain so don't want to paint therefore gel stain seems like a good option.
As I understand, you just clean well and give a light sand and then apply the stain, one or two coats, then a few coats of a top finish.
grinner is offline   Reply With Quote
Old 04-24-2019, 11:39 AM   #2
retired painter
Rewards Points: 2,154
Re: Gel stain on existing cabinetry
I'm the wrong one to ask about gel stains - I don't like them and rarely use them. I have gotten good results tinting poly [like Minwax PolyShades] to darken existing stain a shade or three. It does need to be applied evenly!
mark sr is online now   Reply With Quote
Old 04-24-2019, 08:43 PM   #3
Rewards Points: 3,790
I'm one who typically strips and refinishes so I can't really comment as well. That said, if I were to do this, I think I'd practice on something other than the cabinets first.
stick\shift is offline   Reply With Quote
Old 04-24-2019, 10:00 PM   #4
Rewards Points: 36
I'm practicing on spare doors. It's actually looking good so far.
Old 04-25-2019, 04:49 AM   #5
retired painter
Be sure to give the stain plenty of time to dry, if the stain isn't completely dry brushing on oil base poly can cause it to lift/smear. Waterbased poly may not adhere well to stain that isn't completely dry.
grinner likes this.
Old 05-08-2019, 07:06 PM   #6
klmeenan's Avatar
Rewards Points: 152
I used them on kitchen cabinets for a vacation home. We cleaned really well, then very lightly sanded. We applied 3 thin coats allowing it to completely dry. Then applied poly. We love it. You can still see the wood grain. I will see if I can find a picture.
klmeenan is offline   Reply With Quote
Old 05-08-2019, 10:46 PM   #7
Rewards Points: 36
Very nice. I am currently halfway through my project. So far it's looking great but it is a lot of work.
How long did you let your wood dry after each coat? Did you find the poly removed any of the stain when you applied it?
Old 05-09-2019, 10:17 AM   #8
klmeenan's Avatar
Rewards Points: 152
I let my cabinets dry one day between each application. It took 3 coats for me. The last coat dried over a weekend while I was away. I didnt have any problems of the stain coming off when I applied several coats of poly,
Old 05-09-2019, 11:33 AM   #9
retired painter
Water based polys don't normally lift/smear stain, it's only when brushing an oil base poly over the stain that there is a possibility for lifting.
1950s remodel-New Ducts or repair existing? Dtrain HVAC 6 04-02-2013 07:29 AM
Latex stain on top of Duron Maxwood oil/acrylic stain? farmery Painting 13 03-12-2013 07:55 AM
White stain instead of white paint on a piece of furniture? jbeall Painting 7 01-20-2013 06:47 PM
Best stain for cedar siding pgreef Painting 17 07-08-2011 10:43 AM
join new crawl space CMU footing/foundation to existing CMU basement wall CapeCod153 Building & Construction 4 08-04-2010 07:35 PM
