Gap Between Spicket And Surround - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-10-2015, 10:09 AM   #1
Rewards Points: 2
Gap between spicket and surround
I'm redoing my bathroom and installed the new tub and two of the walls of my surround, but when I tried to put on the third wall (the one with the plumbing behind it) I noticed that the hole I cut in the surround for the spicket was cut at a point where the surround curves (I don't know if you can tell from the picture). So, when I tried to put the spout on it, there's a big gap at the top (see picture). The copper piping comes out too far, so I removed it and have to shorten it, but that wont fix the problem. Any suggestions? Thanks in advance!
Gap between spicket and surround-img_1793.jpg   Gap between spicket and surround-img_1794.jpg
ccc123d is offline   Reply With Quote
Old 07-10-2015, 02:24 PM   #2
Rewards Points: 17,890
There's no "fixing" that one time for a new panel and moving that valve up so it ends up where it's flat.
Old 07-10-2015, 04:39 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 748
Just like a man........... do it, then read the directions.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 07-10-2015, 04:59 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 706
We all know hindsight is 20/20.... and the only alternative I know of is to cut the spout at an angle to match the bevel. Hopefully the spout is a slip on type- not threaded
The Following User Says Thank You to TheEplumber For This Useful Post:
JazMan (07-10-2015)
