Formica Touch-up? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-13-2015, 12:17 PM   #1
PPBART's Avatar
Rewards Points: 1,243
Formica touch-up?
For my first time using Formica, I built a small cabinet. The application seemed to go just fine, but after I finished trim-routing the last edge I noticed a couple of spots where it appears that the Formica has been rubbed through -- like perhaps the roller on the bit stuck(?) Is there some way to touch-up the damaged areas?
PPBART is offline   Reply With Quote
Old 06-13-2015, 03:12 PM   #2
Rewards Points: 144
You can get some touch up stuff from formica in a tube to match.It's a pain to use and may not look perfect depending on any pattern in your laminate but it is available.
mako1 is offline   Reply With Quote
Old 06-14-2015, 06:30 AM   #3
PPBART's Avatar
Originally Posted by mako1 View Post
... touch up stuff from formica ...
Thanks, I'll look for that.
Any tips on how to prevent this from happening? I've got some more sizable projects coming up.
Old 06-14-2015, 07:26 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,486
Do you have a bearing on your bit, if so clean the bearing with lacquer thinner. If your bit doesn't have a bearing, use some type of oil or Vaseline on the HPL the bit rides on, don't cut in long cuts or the bit will get hot and remove the surface of the HPL.
I would suggest getting a good bit that has a good bearing on it, and keep it clean, that is the best way to insure no damage while trimming.
I personally have never had any luck repairing HPL that has been skinned like that, I always had to replace it or just live with it. The filler doesn't stay long as a cover up.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (06-14-2015)
Old 06-15-2015, 05:48 AM   #5
PPBART's Avatar
Originally Posted by BigJim View Post
...I would suggest getting a good bit that has a good bearing on it, and keep it clean... replace it or just live with it...
The bit has a bearing, seems to be free-rolling; however, I tried applying masking tape to protect the surface and the tape showed some damage, like the roller was sticking? Maybe I should check it periodically during cuts(?)
The piece with damage is just a small cabinet top (~20"x36"). I'll try the repair, but sure I'll eventually replace it.
Old 06-15-2015, 05:58 AM   #6
Rewards Points: 1,466
It sounds like you possibly rocked the router base. A feather light touch usually prevents this.
SeniorSitizen is offline   Reply With Quote
Old 06-15-2015, 07:45 AM   #7
Ole Wood Worker
BigJim's Avatar
Turn the bearing with you fingers, (unplug the router first) if it feels rough at all while turning, replace the bearing. Like SS said, there is a chance the cutter got just a hair too close to the HPL, if not, the bearing is freezing up when hot or an excessive amount of glue is locking it down.
If the bearing is damaging the tape then there is something wrong for sure.
Jim
Old 06-16-2015, 05:27 PM   #8
PPBART's Avatar
That's probably a factor... I've been told I have "the touch of an ape". <g>
The Following User Says Thank You to PPBART For This Useful Post:
BigJim (06-16-2015)
Touch lamp stopped functioning properly Spend Electrical 4 02-06-2014 11:05 AM
Mismatch sheen with Aura matte touch up? motifone Painting 10 06-09-2012 11:14 PM
Alternatives to formica? roasted General DIY Discussions 11 01-26-2012 06:29 PM
Bonding formica to old formica MajorMedicalBoy General DIY Discussions 16 11-24-2011 08:45 PM
can I apply formica over formica? DIYWayne General DIY Discussions 7 12-28-2008 03:19 PM
