Foam Spray On Sub-floor Prior To Setting New Tub? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-29-2014, 10:39 PM   #1
Foam Spray on sub-floor prior to setting new tub?
When installing a new tub has anyone ever applied "Great Stuff Gap Filler Foam" spray under tub prior to setting new tub in place - I was watching You Tube tub installation video and the installer applied this to the sub-floor prior to setting tub in place
Please let me know any thoughts or comments on this practice - I was unaware and seen on video
oiler39 is offline   Reply With Quote
Old 04-29-2014, 11:09 PM   #2
Rewards Points: 17,890
No way would I do that for several reasons.
Foam is compressible.
It expands as it dries enough to lift the tub or cause a raised area if it's a fiberglass or plastic tub.
Just follow the manufactures install directions to the letter.
oh'mike (04-30-2014)
Old 04-30-2014, 08:22 AM   #3
Rewards Points: 528
An old plumber told me to put a bed of grout under the tub, because the grout won't shrink as much as typical mortar. I did that when I put in a fiberglass shower stall 10+ years ago and it's still rock solid, and I would do it that way again.
taylorjm is offline   Reply With Quote
XPS Foam on uneven basement wall - Pt.2 (no spray foam) jefferyscott Building & Construction 17 01-04-2017 09:27 PM
Spray foam Question b lowell Insulation 4 01-30-2013 02:34 PM
Spray foam in attic diystephen HVAC 6 12-29-2012 01:07 PM
Spray Foam in Walls & Moisture Question leeave96 Insulation 4 11-12-2012 11:43 AM
Diy spray foam insualtion kits ?? What have I done Building & Construction 3 12-14-2009 08:20 AM
