Floor Support For A Walk In Shower - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-13-2014, 08:22 AM   #1
Floor Support for a Walk in Shower
Hey All,
Thank you in advance for the responses:
I have installed a shower pan using concrete, membrane concrete. It is a 3'x8' walk in shower. To get the proper leveling I used equivalent to 3" of concrete base (x11 60lb) bags or 660 lbs of concrete. The floor joist are 2"x8" and (guessing) 16' long and center to center are 16" apart. The shower is up against a load bearing wall. The concrete is set on 3/4" plywood.
I can access the floor from below but from what I remember, there were a couple water pipes going through the joist.
My question, do I need additional support along the joist? I did some searching but could not find a straight answer so I figured I would post the question to the forum.
chrs6733 is offline   Reply With Quote
Old 08-13-2014, 08:26 AM   #2
Rewards Points: 5,698
Hate to say it, but isn't it a bit late to think about it now? 2x8s seem small for that load, I would expect 2x10s there anyway. But I suppose it depends on local building codes. Being next to the load bearing wall probably helps, since that wall must be properly supported from below. You could sister in another couple joists. The other thing that jumps out at me is the 3/4" plywood subfloor. I would have liked to have started with 1/2" on top of that for 1 1/4" total. Nothing you can do about that now though.
jeffnc is offline   Reply With Quote
Old 08-13-2014, 10:04 PM   #3
Rewards Points: 469
You need to double up all your joist, 2x8x16 will not span 16 feet at 16 inch on center no matter what species of lumber they are. Or you need to put a support beam under them to carry the load
Jnaas2 is offline   Reply With Quote
Old 08-14-2014, 12:10 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Originally Posted by chrs6733 View Post
Hey All,
If your joists (2x8's) are in fact spanning sixteen feet unsupported by any other means you are headed for some heart ache down the road. Those joists now need to be "beefed up". The sooner the better.
jnaas2 is correct.
XXX
Tags
bathroom , floor , floor joist , shower , support
Shower Panel Install Gone Wrong Bushido_Ben Plumbing 10 11-03-2013 07:23 AM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
walk in shower; how to? nap Building & Construction 5 07-20-2008 12:24 PM
