Floor Slope Problem - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Canarywood1
Old 09-08-2017, 03:40 PM   #1
jkk
Rewards Points: 317
Floor slope problem
Wanting to build bathroom in 1966 basement that has crazy floor slope. There's a 2.5" difference in floor elevation over ~7 feet in the area we want to place the bathroom.
I've removed some of the concrete floor for the drains, so I could just remove more as part of leveling the whole area but that's obviously a lot of work. I could just level the shower area and use luxury vinyl tile for the floor but the show area has a 3/4" drop which would have to be leveled.
Complicating factor - the lowest part is at the door, so leveling the floor would mean a large step up at the door. Not very functional. OF course the highest piece is at the exterior wall, so lowering the floor 2.5" would take us near the footing.
Suggestions?
jkk is offline   Reply With Quote
Old 09-08-2017, 04:21 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,612
Re: Floor slope problem
To clarify, this is a concrete floor???
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 09-08-2017, 06:42 PM   #3
jkk
Rewards Points: 317
yes it is
Old 09-08-2017, 07:26 PM   #4
retired framer
Rewards Points: 18,522
What is your plan for the rest of the basement. Are the walls built yet.
Old 09-08-2017, 08:32 PM   #5
jkk
Rewards Points: 317
finishing rest of basement. Walls have not been built.
Foundation wall on one side, bedroom on another, utility room on another and family room on fourth side.
Old 09-10-2017, 04:48 PM   #6
retired framer
If you go down you might run into the footing as many times the floor is just above it.
If the whole floor just went down from settling you might consider mud jacking the floor to bring it back to level.
If you are absolutely sure you are dry you might re-level with sleepers and install a wood floor.
Old 09-10-2017, 05:02 PM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,050
Check out SLC (self leveling cement). A little pricey, and I can't remember how thick/deep you can pour it.....
but I've used it pretty thick... and I add a tight screeding...
have had some in my own place for 20 years with tile... and no problems.
MTN REMODEL LLC is offline   Reply With Quote
Old 09-10-2017, 06:09 PM   #8
Rewards Points: 1,034
The slope is usually because of a center floor drain, floors are usually 4 inches, so as you say a lot of work, i'd live with the 3/4 inch elevation if it were me.
MTN REMODEL LLC likes this.
Canarywood1 is offline   Reply With Quote
Old 09-10-2017, 09:26 PM   #9
Good point ^^^^^^^^^^^^^^^^^^^^^^^^^!!!!
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
