Floor Loading For Clawfoot Tub 2nd Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 02-14-2018, 03:38 PM   #1
Rewards Points: 525
Floor Loading for Clawfoot Tub 2nd Floor
We're going to remodel the 2nd story bath in our 1979-built house. That bathroom currently has a cheapie one piece fiberglass tub, the kind that come with "walls" that fit into the a drywall space. Yuk.
Our plan is to replace it with a smallish "claw foot" style tub, probably one that can be acquired at either Lowe's or Home Depot. Should I be worried that the floor construction may not be robust enough for it? What should I look for after removing the fiberglass thingy?
Curmudgeon10 is offline   Reply With Quote
Old 02-14-2018, 04:25 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,640
Re: Floor Loading for Clawfoot Tub 2nd Floor
What is your subfloor constructed of and what type support is afforded? Joist size and subfloor thickness. What type flooring will you be installing?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 02-15-2018, 01:40 PM   #3
Rewards Points: 525
Yea, I don't know the answers to all those questions yet, as I have not done any demo. Currently there is ceramic tile on the floor, and we will probably replace it with ceramic tile. The entire house, from other remodeling we have done, appears to have subfloor of 1/2" plywood and 3/4" MDF. There is a limited view of the underside of the tub from an adjacent attic space, and it looks like the MDF was omitted under the tub (this would explain why the tub looks like it was made for a dwarf), and it rests on the 1/2 inch plywood.
So the good news is in terms of floor level matching, I have 1 1/4" to work with. But I won't know about joists size and spacing until I do the demo.
Old 02-15-2018, 07:43 PM   #4
Naildriver
chandler48's Avatar
Hopefully it wasn't MDF, but particle board, which still is not a good subfloor product. MDF, likewise will crush under pressure. Your subfloor should be of 3/4" plywood or subfloor OSB and 1/2" plywood or OSB. The joist spacing and unsupported span of those joists will be critical to your installation of ceramic tile.
Nealtw likes this.
Larry......
Old 02-15-2018, 08:12 PM   #5
Rewards Points: 1,466
Ask the seller the tub weight / water capacity and go from their on floor requirements.
We have a 1909 Kohler that weighs in the 400 lb. class. With added weight of water and person I wouldn't put on anything but concrete.
SeniorSitizen is offline   Reply With Quote
Need product suggestions for painting over concrete floor. jaes Painting 7 03-12-2018 11:34 AM
Floor direction for new hardwood over 1925 hardwood on sleepers? jsimma Flooring 2 07-21-2015 04:47 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
