Floating Shower Bench Seat - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By PappyO
Old 09-28-2017, 05:38 AM
Rewards Points: 92
Has anyone installed a floating type bench shower seat. I really don't like the box type.
This first one I guess you just build it into the framing but other (2) look like they are floating.....maybe fasten back inside the wall.
PappyO is offline
Old 09-28-2017, 10:27 AM
Rewards Points: 898
Re: Floating Shower Bench Seat
These corner ones are probably the simplest and cheapest.
Google goof proof shower seat.
BIG Johnson is offline
The Following User Says Thank You to BIG Johnson For This Useful Post:
PappyO (09-28-2017)
Old 09-28-2017, 10:34 AM
retired framer
Rewards Points: 18,480
I think you could have all kinds of trouble with that, from re enforcing the studs to waterproofing and movement over years of use. Not sure what would be done on the underside. Drip edges and cleaning. I would leave that wheel for others to invent.
Nealtw is online now
The Following User Says Thank You to Nealtw For This Useful Post:
PappyO (09-28-2017)
Old 09-29-2017, 08:21 AM
Rewards Points: 996
i am sure those (not the small corner seat) have a very sturdy metal frame.
you want to play, you got to pay ....
Fix'n it is offline
The Following User Says Thank You to Fix'n it For This Useful Post:
PappyO (09-29-2017)
Old 09-29-2017, 01:08 PM
Rewards Points: 92
I think I'm going to ask around for someone to make me some stainless steel custom brackets or online
PappyO is offline
Old 09-29-2017, 01:15 PM
retired framer
If you could get a real good attachment to the stud, 200 lbs sitting on the seat will have some leverage and the studs will bend the grout will crack and the wall will leak and the wood will rot.
You have much more homework to do before you solve the last problem.
First problem is what weight you could attach to a stud and how to stop the stud from bending.
PappyO (09-29-2017)
Old 09-29-2017, 01:25 PM
Rewards Points: 92
Well I'm a fat old man and I'm sure those are all valid points but I'm sure with some thought I can overcome these challenges ahead
PappyO is offline
Old 09-29-2017, 01:39 PM
retired framer
I think the brackets almost have to screw to the side of studs and go floor to ceiling.
Then sealing around the bracket in the shower would be next, would it be best hidden inside shelf.
PappyO (09-29-2017)
Old 09-30-2017, 08:33 AM
Rewards Points: 996
that bracket would be a start.
Fix'n it is offline
Kemper100 (09-30-2017)
Old 10-10-2017, 02:37 PM
Rewards Points: 92
I contacted a stainless steel fabrication shop to fabricate a seat to span the distance of the shower and rest on the framing, hopefully this will be the answer.
Nealtw likes this.
PappyO is offline
Old 10-11-2017, 01:02 AM
Rewards Points: 8
I never tried installing it but by seeing the marble one in the image, will surely try now. Is there any better options?
larryeiteljorg is offline
Shower Panel Install Gone Wrong Bushido_Ben Plumbing 10 11-03-2013 07:23 AM
Shower bench seats ladytiler Tiling, ceramics, marble 4 01-08-2013 10:41 AM
tiling a built-in shower seat diy'er on LI Tiling, ceramics, marble 14 02-25-2012 08:14 PM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 05:09 AM
Mortar to use in floating a shower pan? kemerick Flooring 2 11-12-2007 01:35 AM
