Fix Shower Door Catch - Ball Is Stuck - Failed Spring? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-23-2015, 08:05 PM   #1
Rewards Points: 16
Fix shower door catch - ball is stuck - failed spring?
Hey folks,
1st time poster, 1st time homeowner here.
My shower door doesn't stay closed. (Funny that it did during the open house.)
It looks like the ball in the shower door catch is stuck in the depressed state. Now I'm depressed too. How does this work? Is there a spring behind it that failed?
More importantly, how do I go about fixing this?
dtcdtcdtc is offline   Reply With Quote
Old 08-24-2015, 07:02 AM   #2
Retired Moderator
Rewards Points: 7,174
A picture might help----I've never seen a mechanical latch on a shower door--just magnetic.
Old 08-24-2015, 07:20 AM   #3
Rewards Points: 5,348
Sounds like a spring loaded catch. Try shooting a lubricant into the latch mechanism. Spray silicone or white lithium grease to see if it releases the ball. If not, the spring is probably broken behind the ball.
Are there screws on the latch you can remove? If there are, take them out and look at the mechanism. Careful to not lose any parts and keep track of how it went together. If the spring is broken, get one to replace it. They sell bags of springs online. I bought one when the spring in my Andersen screen door broke.
Ron
B. Franklin 1759
Old 08-24-2015, 02:39 PM   #4
Rewards Points: 16
It looks like I'm too new to posts links, unfortunately.
Here's an unlinked link: s1192.photobucket.com/user/honestabe20/library/ShowerDoor
Old 08-24-2015, 03:02 PM   #5
Looks like a friction fit ball latch. It's pressed in place and held there by the door frame.
These can be a little tricky to remove. Wear leather gloves doing this. Using a knife blade, get behind the flange and gently pry it out a bit. Then go to the opposite side and do the same. Work your way around the perimeter until it pops out.
Hopefully this is a serviceable unit and can be repaired.
Take some photos of it when it's out.
You can also put another device on the inside to do the job of keeping the door closed if the latch issue can't be repaired.
Ron
B. Franklin 1759
Old 08-24-2015, 03:59 PM   #6
Rewards Points: 16
Yikes. That sounds beyond my level of skill / risk.
I guess I'll try to find another way to keep this closed. I was thinking of using magnets, but the door itself isn't magnet-izable.
Old 08-24-2015, 04:28 PM   #7
It doesn't have to be. Just attach a magnet(this will rust over time if not painted) to the inside of the door(at the top corner) Then attach a metal bar(painted so it doesn't rust) to the top of the frame inline with the magnet
You can also use a brass barrel bolt on the inside of the door.
Ron
B. Franklin 1759
Old 08-24-2015, 06:04 PM   #8
Retired Moderator
Peal and stick rubber magnets (sold in rolls ) can be used---look at the shower door displays --most use them---then ask where the replacements are kept.
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Shower Rough In - Miscellaneous Questions tev9999 Plumbing 1 02-13-2012 09:40 PM
Delta Ball Joint shower arm adapter??? nic3456 Plumbing 3 11-10-2010 10:01 AM
Delta shower lever ball questions.. topspin Plumbing 1 08-15-2008 08:57 AM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 09:19 PM
