Filling A Hole In The Bathroom Ceiling - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-25-2014, 03:35 PM   #1
Filling a Hole in the Bathroom Ceiling
Hello everyone!
I recently moved into an old brownstone and realized that there is a cockroach issue in the entire building. I'm working on getting rid of them but the other night I noticed some were near the ceiling above my shower.
There is a pipe in the corner of the shower that is a couple inches thick and runs up to the ceiling. Where it connects to the ceiling there is a large gap on all sides I want to seal it.
Any suggestions? I was told steel wool and expandable foam, but want to know if that is sensible to do right above the shower where it is likely to be humid..
Picture is attached to provide reference
Thanks to all!
Zee in BK is offline   Reply With Quote
Old 06-25-2014, 05:36 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,054
I'm really not sure what Cockroaches will go thru..... I would think a good bead of Silicone would do the trick.
MTN REMODEL LLC is offline   Reply With Quote
Old 06-28-2014, 06:26 AM   #3
Rewards Points: 2,494
Second silicon. Also behind that shower arm cover plate. Any opening between wall and trim (base molding, etc).
carpdad is offline   Reply With Quote
Tags
bathroom , hole , shower
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
drywall ceiling repair after bathroom fire help nilewaves Drywall & Plaster 9 06-07-2011 03:33 PM
Filling a large hole in basement! rotteneggz Building & Construction 4 10-01-2010 06:11 PM
Tar bleeding through paint on bathroom ceiling dwoloz Painting 5 08-15-2010 08:10 PM
Is it ok to use the shower without a ceiling in the bathroom? Bigguy0 Building & Construction 5 10-24-2009 07:26 PM
