Electric Cooktop - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 07:49 AM   #1
electric cooktop
I need to replace my cooktop and discovered the cutout measurement is more important than the size of the cooktop! I can't quite see or reach the areas to measure from inside the cabinet. There are lots of pieces of "wood" attached to other pieces. . . I can't quite see or feel the edges of the opening. I'm afraid to disconnect the entire thing to see the opening from the top. The countertop is tiles and I don't want the mess and expense of breaking them to enlarge a hole. Thanks, Patti
Patti H is offline   Reply With Quote
Old 07-17-2012, 07:59 AM   #2
Rewards Points: 582
hi patti some cooktops if not all go by the measurements on the unit itself...example,,,if you measure 30" across your cooktop..its a 30" order...if it measure 36" then its a 36.....and it should fit your opening...how old is the existing cooktop....
Old 07-17-2012, 08:16 AM   #3
Thanks Ben,
The old one is about 20 years. A Kenmore. I can not reach to the back of the cabinet to get a good measurement or see the sides because of stuff in the way.
The part holding the knobs is in the way on one side and I can't see or feel the edge.
I'm getting approx. measurements of 26.5 x 19.75 but the top of the cooktop is 28.5 x 20.5.
Maybe I should just call Lowe and have them deal with it.
I thought his would be easy!
Electric cooktop wiring issues kbrookst Electrical 17 04-13-2012 01:36 PM
Electric Cooktop too slow to heat coachgns Appliances 1 02-05-2011 03:45 PM
Changing 220V to 110V (hardwired) for an electric to gas cooktop switch. charleyhart Electrical 14 01-15-2011 01:12 AM
Electric Cooktop partially heating bna1dew Electrical 4 11-04-2010 01:20 AM
Electric cooktop vs. Gas cooktop Krichton General DIY Discussions 5 06-16-2008 07:26 AM
