Easiest/Cheapest Shower Replacement? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-01-2014, 11:27 AM   #1
Rewards Points: 78
So, in my new home I have a basement shower than needs work. I have yet to tear out the rotten walls, but this is what I know so far-
It is larger than average. ( I think 45" square, I can go remeasure soon)
It had 4'6" tall tileboard walls (the boards with a tile print on them)
The boards were rotten through in a few parts at the bottom.
One wall was just the board glued up to the cinder block foundation.
The other three walls were fastened to regular drywall. Not cement board.
The floor is just painted cement.
So, most of the drop in shower options are too small for this setup. Realistically, I just want something that I can get operational ASAP. I'll probably do a real remodel later down the road when the funds are available. So cheaper is better. I don't want to cut corners, but don't really care about it being super nice (aesthetically, not quality). Just something that will last 3-5 years.
Ideas? Should I rip out the framing and frame it to a more common size, or just slap something up on the current setup?
gijoe985 is offline   Reply With Quote
Old 12-01-2014, 11:47 AM   #2
Rewards Points: 144
"Do a job,big or small,do it right or don't do it at all"
You need to fix all these issues.It won't get any better in 3-5 years..Least expensive,and quickest, would be to fix the water issues and put in a one piece fiberglass shower
mako1 is offline   Reply With Quote
Old 12-01-2014, 02:21 PM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,182
It is larger than average. ( I think 45" square...
Divide the job by parts.
Part #1 is the pan/base and drain plumbing.
Hire help if needed but do this RIGHT.
Part #2 is the walls.
Here you can get creative but start with RedGard on MR sheetrock.
Heck, that might be all you need for your time frame.
On top of the GWB/RedGard? FRP works well. Epoxy Paint will too.
Old 12-01-2014, 02:48 PM   #4
Rewards Points: 78
Ok, good stuff, thanks. I really just needed some affirmation.
Mako1- I thought about dropping in the fiberglass shower, but that would require framing everything again. I figure in 3-5 years I will be gutting it entirely and doing the whole place from scratch. But for now I just want one that works. We hardly use the basement floor. But it is nice for guests.
So, on to new questions-
1)Can I just assume that if the drain was functioning perfectly fine that I can leave it as is? I could repaint the floor? Could I put FRP on the floor?
2)MR sheetrock on 3 walls, what about the cinder block wall? Sheetrock on top of that, or will RedGard right on top?
THANKS!!!
Old 12-01-2014, 04:10 PM   #5
MarginallyQualified
Probably... but never ASSume anything. (get it checked)
1a) I could repaint the floor?
Epoxy on the floor. (garage floor epoxy kit with speckles even -I've done it)
You may even be able to get away without using a pan (I have).
Redgard on all walls and on top of the (cleaned) block.
eta: This is my RV bathroom.
Five years later it's still doing great.
(walls are FRP over 1/4" ply )
Easiest/Cheapest Shower Replacement?-redgard-onwood.jpg   Easiest/Cheapest Shower Replacement?-epoxyoverredgard.jpg
Old 12-01-2014, 04:14 PM   #6
Rewards Points: 78
Yeah, there is no pan in there right now. Just a drain in the cement floor...
Old 12-08-2014, 10:18 AM   #7
Rewards Points: 78
Would it be ok to use FRP on the floor?
Ceramic shower stem drop in replacement TexasPenguin Plumbing 0 10-09-2012 10:29 AM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 09:22 PM
Shower Arm Replacement - Please Help Detroitphan Plumbing 7 03-06-2011 10:52 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 01:59 PM
