Drywall Or Plywood For Kitchen Wall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 01:26 PM   #1
Drywall or plywood for kitchen wall
I'm installing a kitchen wall where upper cabinets will be installed. I'm wondering if I should install plywood or drywall on the studs. Seems that advantages for plywood are:
a. bettter hanging capability
b. flatter, smoother surface
If I install tile on the wall, will tile adhere to the plywood as well as the drywall?
Any recommendations?
robert wilson is offline   Reply With Quote
Old 02-20-2012, 01:44 PM   #2
just put blocking in between the studs where the tops and bottoms of the cabinets will be and drywall over everything. you will still have plenty of wood to screw the cabinets to and wont even have to measure if you get blocking between all the studs and tile on wood is not a good idea. if you use plywood and have to paint any of it it will look like painted plywood.
Attach drywall at the wall bottom Restyle Drywall & Plaster 8 12-15-2011 10:25 PM
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 10:47 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Drywall Bulge after installed TV wall mount tstecko Drywall & Plaster 15 03-23-2010 07:35 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
