Drywall Behind New Tub Surround - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-30-2016, 11:17 PM   #1
Rewards Points: 4
Drywall behind new tub surround
Hello,
I am ripping off our tiled drywall and putting in new drywall and a glue up tub surround. I would have liked to put in a direct-to-stud surround but we have a window to go around. It doesn't appear the direct to stud surrounds can be cut to accommodate a window.
After I put in the new drywall, is it necessary to mud and tape the joints behind the surround?
AfroJoJo is offline   Reply With Quote
Old 12-31-2016, 01:33 AM   #2
JUSTA MEMBER
Rewards Points: 3,462
Re: Drywall behind new tub surround
No.
The tape and mud is only needed , so you have a flush wall to be painted.
I have put up plenty, and then put paneling ( staggered), or other wall covering over the drywall.
Try to not use the joint stud for a place to nail / screw your surround to, this area is lower than the rest and might cause warping of the surround.
No tape needed.
ED
de-nagorg is online now   Reply With Quote
Old 12-31-2016, 06:39 AM   #3
hkstroud's Avatar
Rewards Points: 5,742
I would tape and mud. I would also use a cement board tape and mud with thinset, smooth side out.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 12-31-2016, 10:49 AM   #4
Rewards Points: 4
My thoughts were that the joint compound would not give the adhesive for the surround walls the best possible surface for adhesion.
Old 12-31-2016, 08:46 PM   #5
Rewards Points: 382
Yeah, if you mud, you should prime.
If you don't want to mud and are worried about the factory taper throwing anything off, cut the taper off before hanging
Erico is offline   Reply With Quote
Old 12-31-2016, 09:32 PM   #6
RRH
Rewards Points: 1,312
I would stick with attachment to studs model.
try www.sterlingplumbing.com the Vikrell series has a surround that can be cut and they have a window trim kit for it.
RRH is offline   Reply With Quote
How to repair a doorknob hole in drywall Sir MixAlot How To Guides 5 01-27-2015 07:17 AM
Shower surround drywall questions spring3100 Drywall & Plaster 7 12-06-2012 12:26 PM
Tub Surround Over Existing Drywall? DrHicks Tiling, ceramics, marble 10 11-18-2012 12:05 PM
Added new Fireplace Surround need drywall tips rocketdoctor Drywall & Plaster 2 12-06-2009 06:14 AM
drywall above Tub Surround Craigsutton Remodeling 1 03-14-2009 06:56 PM
