Doing A Shower With Schluter - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-13-2017, 11:39 AM   #1
Rewards Points: 270
Doing a shower with Schluter
I'm going to be redoing a small shower and think the easiest way to go would be to use the schluter system with kerdi board. My question is, once I have the kerdi installed, is there a pre-mixed thinset that I can use to install the kerdi strips that cover the seams and the washers? Also, can that same thinset be used to install the foam pan to the floor and the tiles over the kerdiboard or do I need different mixes?
joeg679 is offline   Reply With Quote
Old 05-13-2017, 06:45 PM   #2
Rewards Points: 898
Re: Doing a shower with Schluter
No such thing as pre mixed thinset. Use what Schluter tells you to use.
BIG Johnson is offline   Reply With Quote
The Following User Says Thank You to BIG Johnson For This Useful Post:
joeg679 (05-13-2017)
Old 05-13-2017, 06:52 PM   #3
Rewards Points: 270
ok, thanks
Old 05-14-2017, 11:51 AM   #4
firehawkmph's Avatar
Rewards Points: 2,550
Joe,
If you haven't already, go to Schluter's website and you can download their installation manual and also watch videos that show exactly how to install their products. Don't try to vary from the process and you shouldn't have any troubles. Plan ahead before mixing your thinset. You can have all your kerdi material precut to size beforehand. Then you will have enough time to install it. No shortcuts.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
joeg679 (05-14-2017)
Old 05-14-2017, 11:54 AM   #5
Rewards Points: 270
Originally Posted by firehawkmph View Post
Joe,
Mike Hawkins
Thanks - yes, I'll be doing that. There are a lot of installation videos online, which is great and the system seems pretty straight forward.
General Questions w/ Pics on 1st Time Shower Pan Build/Install amodoko Plumbing 10 06-10-2015 03:45 PM
Problematic shower oneonesix Plumbing 25 12-28-2014 12:52 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
