Do I Need Backsplash? Or Will Trim Suffice? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-15-2014, 02:15 PM   #1
Rewards Points: 578
Do i need backsplash? Or will trim suffice?
My walls are white beadboard, with shelves instead of upper cabinets. The lower cabinets are painted white with shaker style doors.
My countertops are laminate, the color of raw wood, and are not the kind with a built-in backsplash.
Do i need to put in a backsplash? If so, what kind of backsplash would look good attached to white beadboard?
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 08-15-2014, 02:17 PM   #2
Rewards Points: 578
I have some trim i was gonna put on the back of the countertop to protect against water and food particles getting back there, i wont leave it exposed
Old 08-16-2014, 08:17 AM   #3
Rewards Points: 996
if the gap isn't big = caulk.
Fix'n it is offline   Reply With Quote
Old 08-18-2014, 08:11 AM   #4
Rewards Points: 578
the gap is too big for just caulk. The wall is not straight so it was impossible to get a tiny gap. I got some trim that will cover it, and ill put caulk along the top and bottom edge of the trim, but i cant use just caulk.
Old 08-18-2014, 08:44 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
A backsplash is not required, but a lot depends on the specific area and how many slobs are in the house.
I don't see a problem with leaving just the beadboard with caulked trim behind the general counter top areas if that's what floats your boat.
The sink is iffy. You might get away without one if you have a good quality semi-gloss paint, and are OK with repainting if necessary.
You definitely want to install something scrubbable behind the cook-top.
Old 08-18-2014, 08:56 AM   #6
Rewards Points: 578
thank you, Blondesense. I will look into backsplash options for those areas... Any idea what kind of backsplash might look good against beadboard?
Old 08-18-2014, 03:41 PM   #7
Rewards Points: 578
ok i found something that might work, if painted with quality semi-gloss paint. Of course i would paint the beadboard too, behind the sink and stove.
#1, would this work?
#2, where do i find this, preferably already primed? I dont recall seeing one of this style at Home Depot, although i could be wrong
Old 08-22-2014, 11:32 AM   #8
Maryland
Maybe I'm under-thinking this... but just about any pre-primed moulding would work... no? Like a length of stop moulding. The box stores carry all kinds of this stuff in pre-primed pine. Then as you said, caulk the seams where the moulding meets the bead board and the countertop.
Pittsville is offline   Reply With Quote
Removing latex paint from wood trim ulbass Painting 8 09-13-2017 05:46 AM
How To Seal Tyvek Terminations At Wood And Composite Trim? gunner666 Roofing/Siding 5 08-06-2014 01:52 AM
Replacing Small Sections of Rotted Trim FrazzledMom Carpentry 2 07-07-2014 06:15 PM
window trim lendosky Windows and Doors 0 01-13-2014 02:26 PM
Old Flooring and Trim Identification and Refinishing BungalowBaby Flooring 8 07-02-2011 06:17 PM
