Distance From Toilet To Freestanding Tub - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 04-29-2017, 12:57 PM   #16
Rewards Points: 22
Re: Distance from toilet to freestanding tub
Originally Posted by jaketrades View Post
How much smaller of a toilet can you get? 27 3/4" is on the smaller side of what I've seen. I'll google around.
I missed the measurement on the toilet size. I found a compact Kohler on Home Depot's website but it looks like 27 3/4". I don't know if there is anything out there smaller than that or not.
G'terDone is offline   Reply With Quote
Old 04-29-2017, 01:36 PM   #17
Rewards Points: 764
Guys I'll draw a proper diagram with graph paper and post later today. Don't struggle reading my chicken scratch doodling.
jaketrades is offline   Reply With Quote
Old 04-29-2017, 06:03 PM   #18
Rewards Points: 764
Ok here's a diagram with the shower across from the toilet. The distance from toilet to shower is now 32 1/2".
6" more spacing for the crapper from what I had initially.
The spacing between the tub and shower glass is tight. At its tightest the gap will be 1 3/8" and grow larger from thereZ. Ideally I'd like a smaller tub but it's been hard to find.
Still too cramped?
Old 04-29-2017, 06:08 PM   #19
Property Mgt/Maint
Rewards Points: 6,356
I wouldn't skimp on the toilet in a premium condo. I'd stick with the oval and deal with the spacing another way. Since this isn't technically a master bath, but a shared main bathroom, I still fail to see the practicality of the double bowl.
Yodaman, when you say looks to cramped, do you mean the tub or shower to toilet distance or the overall bathroom looks too cramped?
This is my first diy project so my perspective isn't that good.
To me the whole space looks cramped, kinda like a subway car. But when drawn up to scale may be a little better.
I would recommend working with a designer that can lay everything out and allow 3D viewing. The box stores don't charge for the service, but they will spec their products.
Yodaman is offline   Reply With Quote
Old 04-29-2017, 06:09 PM   #20
Rewards Points: 764
Originally Posted by SeniorSitizen View Post
According to your first drawing, that would give you the most available space between the tub and vanity, and I agree, double vanity all the way.
The most space near the door opening is most convenient and the lower height tub as opposed to the shower across from the vanity would be much better in my opinion by giving more upper body room.
I see nothing wrong with the space between the shower and toilet. Be certain the toilets you are considering have the correct dimension for your rough in distance ( 10" or 12" ) possibly or other.
Excellent point about the upper body room near the vanity. I hadn't considered that.
Old 04-29-2017, 06:37 PM   #21
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,264
Your layout is fine.
I would use an elongated bowl.
28" is code here.
Almost 4' between the tub and vanity. Why is everyone seeing this as cramped?
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is offline   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
jaketrades (04-29-2017)
Old 04-29-2017, 06:57 PM   #22
Rewards Points: 1,466
Still too cramped?
Excellent, and be certain the door is wide nuff for wheel chair access. Seems like 28" is minimum. Far too many have 24 doors.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 04-29-2017, 06:58 PM   #23
Property Mgt/Maint
It does look better on the graph paper. When I made my comments I was going off the hand sketch on post 15
The Following User Says Thank You to Yodaman For This Useful Post:
Old 04-29-2017, 09:35 PM   #24
Rewards Points: 764
Yeah that was after a few ipas.
Old 04-29-2017, 09:36 PM   #25
Rewards Points: 764
Appreciate all the help. You guys saved me from a foul up. Thx!!
Old 05-02-2017, 06:01 PM   #26
Rewards Points: 764
I'm going to leave 4 inches from the wall and the freestanding tub. Sound about right?
That way someone can clean behind it or retrieve dropped items. You'd have to climb into it to clean behind.
Old 05-02-2017, 06:09 PM   #27
123pugsy's Avatar
I like the idea of being able to clean. Kind of important.
4" sounds good. That way you can tell the wife to grab stuff because your arm won't fit.
jaketrades (05-02-2017)
Old 05-03-2017, 06:22 PM   #28
Tileguy
JazMan's Avatar
Rewards Points: 748
What's the width of the toilet area? From wall to vanity top overhang? Also from toilet center line to each?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 05-03-2017, 06:48 PM   #29
It looks to me each square is 6" on the graph paper.
Old 05-03-2017, 06:54 PM   #30
Rewards Points: 764
Jaz
Toilet area is 35".
Toilet center line to wall and vanity ideally would be 17.5".
Now that you've got me thinking about it I'm not 100% sure that's the case. because of the existing rough in But it'll be pretty close.
Toilet not flush with floor in front right!! L.Young Plumbing 1 10-09-2015 06:42 AM
Toilet distance from bell to base Olcrazy1 Plumbing 10 01-12-2015 08:47 PM
Toilet Install Went Wrong, Poor Plumber Choice pbrigante Plumbing 12 08-10-2014 09:35 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
