Distance Needed For New Toilet And Shower - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 3 Post By MTN REMODEL LLC
  • 1 Post By KC_Jones
Old 03-31-2017, 10:25 AM   #1
Rewards Points: 54
distance needed for new toilet and shower
Hi,
Trying to figure out the dimensions for a possible bathroom (if we can fit it). I know the plumbing can work out for it already.
Can someone help me check the distance I would need from right to left in order to insert a toilet and one-piece 32 by 32 shower next to one another against a shared back wall?
In other words:
1. Beginning from a currently finished side wall on the right, how much lateral distance does the toilet need to the left before I add:
2. a framed 2by4 wall alongside the right side of the shower insert (finished only on the toilet side), then
3. the 32 by 32 shower insert rough opening, then,
4. a new outside wall alongside the left side of the shower
I was thinking I would need:
18" side to side for the toilet; plus 4" for the wall along one side of the insert's rough opening (again allowing for drywall only on the toilet side); plus the 32" insert's rough opening; plus another 4" for a new outside wall along the other side of the insert, plus another 3/4 for baseboard trim on the outside of the new wall).
A bare minimum of 59 inches from side to side. Does that look right?
dweeter is offline   Reply With Quote
Old 03-31-2017, 11:59 AM   #2
Rewards Points: 1,466
Re: distance needed for new toilet and shower
With the toilet centered in its space, at minimum it needs 10" each side of the toilet base from the walls baseboards and 12 inches is better. So toilet base width + 20" or 24" + 4" wall + 32" shower it's looking like 64" at least.
We have an identical situation with a 35" shower. The wall to wall space minus baseboards is 72" and any smaller wouldn't be good in my opinion.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
jaysurfs (04-23-2017)
Old 03-31-2017, 11:59 AM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,050
Dweeter....... You can't squeeze a toilet in 18"..... I doubt you could physically fit it.....
I don't have my code in front of me.... but I'm thinking code is 15" each side....
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 03-31-2017, 12:08 PM   #4
Rewards Points: 426
There must be a minimum of 15″ from each side of the toilet to its center per code.
MTN REMODEL LLC likes this.
KC_Jones is offline   Reply With Quote
Old 03-31-2017, 01:32 PM   #5
Rewards Points: 54
Oh yeah... duh. I was leaving a generous 18 inches on either side of the toilet, but I forgot to double that figure. Maybe I will go down to 15 as per code and make the toilet space 30 inches.
Thanks all.
Old 03-31-2017, 01:54 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 706
30" required for a WC (15" from center to wall/obstruction) and you also have a minimum sq. inches for a shower. It's 1024 sq" in my area. Minimum width of 30"
put shower over toilet stack? DanInDetroit Plumbing 7 08-13-2015 11:36 PM
Shower and toilet clogged droopdog7 Plumbing 16 03-11-2014 05:56 AM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Toilet won't flush unless shower is on! applejack Plumbing 19 02-10-2013 09:06 PM
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 01:50 PM
