Depth Of Delta Bath Valve - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-29-2018, 07:57 AM   #1
Rewards Points: 462
Depth of Delta bath valve
Having a hard time interpreting the instructions on this. Does the black plastic guard stop on the back side of the cement board or the outer surface or the finished tile? Or somewhere in between? The piece of scrap plywood represents where the cement board is going to be. I plan to use a standard 1/4 inch thick 12 X 12 ceramic tile.
Depth of Delta bath valve-image_1517234176547.jpg   Depth of Delta bath valve-image_1517234193662.jpg   Depth of Delta bath valve-image_1517234215131.jpg
Jim F is offline   Reply With Quote
Old 01-29-2018, 10:22 AM   #2
Guapo
Rewards Points: 11,950
Re: Depth of Delta bath valve
Who mounted the shower body & did he ask you where you wanted it? It changes with the type of shower wall.
Guap0_ is offline   Reply With Quote
Old 01-29-2018, 10:34 AM   #3
Rewards Points: 462
I sweated the shower body in but have not yet secured it to the studs. The lengths of the supply pipes gives me enough flexibility to mount it where it needs to be. And I realize a professional plumber would have mounted the body first but I wanted to get water supply secured first knowing that I could go back and mount the body afterword.
Old 01-29-2018, 10:43 AM   #4
Guapo
From the pic, it appears that there are mounting holes, for a cover plate. If that's the case, those holes should be flush with the tile or plastic surround, whatever you use.
The Following User Says Thank You to Guap0_ For This Useful Post:
Jim F (01-29-2018)
Old 01-29-2018, 11:06 AM   #5
Peace be with you
DR P's Avatar
Rewards Points: 1,860
as your details show -
historically you need at least a 2x4 behind rough
valve to allow finished trim to properly install
ideally - front edge of plaster guard
is flush with finished wall...
with 3/8" allowance forward or inwards
Edit: be sure you insulate well behind that valve/piping
as it appears to be possibly an outside wall
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
Jim F (01-29-2018)
Old 02-01-2018, 07:53 PM   #6
Rewards Points: 462
It is an exterior wall. I used extruded foam insulation on that area behind the wet wall mostly out of frame. The area behind the valve I plan to hit with a can of great stuff which I've used before.
What is "subflush" (regarding Delta R10000 shower valve)? squarewav Plumbing 9 01-01-2016 04:56 PM
Shower Valve & Head Depth 325_man Plumbing 6 07-11-2014 08:41 PM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
New Delta rough in valve question Bonzoso Plumbing 13 05-17-2013 07:15 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
