Definitive Shower Remodel Wall Construction/Prep - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2015, 09:44 PM   #1
Rewards Points: 34
I have a builder-grade marble tile shower with plastic pan, and the adjacent wall surrounds that I would like to remodel. I'd be taking out the marble tile and the pan, as well as the added thickness of (green?) sheetrock that seems to be immediately under the marble tile. Maybe I'd take it all the way down through the base drywall to the studs, if appropriate. My shower is on all-interior walls, and directly on the slab foundation.
Is there a definitive guide to constructing and prepping walls for a shower? I've searched this forum, and have turned up about as many variations as there are posts, e.g. hardibacker/no hardibacker, membrane (nail it/don't nail it), green sheetrock, cover the lip of the shower pan/don't cover the lip of the shower pan, etc...
I want to put in a single piece, solid stone (marble or quartz) pan, so I would rather this be a "40 year" shower, rather than a "15 year" shower (as one poster on here put it), so having a good resource for proper shower building would be invaluable. I thought info like this may be in a sticky somewhere, or at least a wall cross-section illustrating the various layers, but that doesn't seem to be the case. Seems like everyone has their own way of doing things, but what is right?
I would tend to follow the manufacturer's installation instructions for the pan (although some seem to thumb their nose at manufacturer info), so maybe my question comes down to wall construction and treatment.
I'm hoping someone can point me to a link, or some building code site that details this type of construction.
Any thoughts?
DBB1959 is offline   Reply With Quote
Old 02-16-2015, 06:46 AM   #2
Retired Moderator
Rewards Points: 7,174
The definitive book on shower building is the TCNA manual---(tile council of north America)
Unfortunately ,this must be purchased and is not available on line---
Old 02-16-2015, 07:05 AM   #3
Rewards Points: 454
I would follow the manufacturers instructions. it might seem like over kill but my opinion is there isn't over kill when it comes to water
scottktmrider is offline   Reply With Quote
Old 02-16-2015, 01:28 PM   #4
Rewards Points: 34
Sounds like a good investment to me. I'll see if I can locate a copy. This is exactly the kind of info I was hoping to be pointed to.
Thanks!
Old 02-16-2015, 01:32 PM   #5
Rewards Points: 34
I agree 100%. But as great as these forums are (they've helped me out more times than I can remember), you really see a bit of everything, to the point of not knowing what's right.
I usually take a lot of this info and use it as a starting point, then research the hell out of it, which is why my projects are sometimes slow to start, much to the dismay of my wife...
Thanks for the reply!
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Framing wall for shower surround quackaddict Building & Construction 2 03-10-2013 07:17 PM
Delta shower valve replacement on exterior wall muellertr Plumbing 6 01-02-2013 07:07 AM
Ideas for shower odd wall enigmaingr Kitchen & Bath Remodeling 3 08-18-2011 08:43 AM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 04:13 PM
