Cutting Travertine - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-09-2017, 05:23 PM   #1
Rewards Points: 60
Cutting travertine
I'm putting down 12x12 mosaic 3/8" thick travertine tile on my shower floor but I need to cut several of the pieces down to about 3/8-1/2" pieces. I have an angle grinder, so can I just use a standard diamond tip blade to cut these? I have one and I tested it on a piece but its chipping the surface of it. I just wanted to see if there was a different type of blade I should be using or if the one I have is starting to go dull. Here is a pic of the tile I'm using
Keiv is offline   Reply With Quote
Old 09-09-2017, 05:34 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Re: Cutting travertine
Unless you are a brain surgeon, I doubt you can hold the grinder steady as it spins at 10,000 RPM. You should really be using a wet saw, whether it be a cheap under blade model or a bridge model. You can rent one fairly inexpensively, and it will give you much better results.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Flooded_drywall cutting questions_suggestions tearitup Drywall & Plaster 34 09-01-2017 09:50 PM
Cutting tabs at round pipe end to connect to box amakarevic HVAC 7 12-26-2013 02:38 PM
Cutting hole for outlet in tile RichardZ Tiling, ceramics, marble 5 12-18-2013 09:18 AM
Growing A Willow From A Cutting...How/When To Prune? JL-KA Landscaping & Lawn Care 2 10-09-2013 04:24 PM
Travertine Flooring & load bearing John Reiff Flooring 3 08-17-2008 08:51 AM
