Cutting A Stud To Mount A Recessed Medicine Cabinet? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 08-04-2018, 04:44 PM   #1
Rewards Points: 110
cutting a stud to mount a recessed medicine cabinet?
I am mounting a new recessed medicine cabinet in the center of a 58" vanity wall. This cabinet has a 30x24" large oval mirror as its door.
The cutout to mount it in the center of the 58" wall will require that a 14" x 18" hole be cut out of the drywall. The 14X18 hole will involve a stud behind the drywall.
Will it be save to cut out a section of the stud to accomplish this?
Would I be able to construct a wood frame around the hole to mount the cabinet. Is there another easier way to mount/secure the recessed portion
to the drywall without building a frame to screw in the right&left sides of the cabinet
provlima is offline   Reply With Quote
Old 08-04-2018, 05:26 PM   #2
retired framer
Rewards Points: 18,756
Re: cutting a stud to mount a recessed medicine cabinet?
IF it is a non bearing wall. it is not a problem. After cutting the hole to fit you can slide a block of 2x4 behind the edge of the drywall and screw thru the drywall to hold it there and screw the box to that.
lenaitch likes this.
Tags
drywall cutting , stud
mount cabinet on porcelain wall picturecar Kitchen & Bath Remodeling 3 04-09-2018 11:09 PM
Medicine cabinet height recommendation jaketrades General DIY Discussions 12 07-20-2017 02:33 PM
hanging kitchen cabinet with no stud on 1 side Olcrazy1 Carpentry 8 02-27-2015 09:41 PM
help with medicine cabinet stash823 Kitchen & Bath Remodeling 7 02-13-2013 01:03 PM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 10:08 PM
